Re: Laser tube wont start
Hello dear.
Good morning to you.
Jinan SUKE Science& Technology CO.,LTD specialized in laser machine with CE&FDA ceritificate with 6 years epxerience.
About your questions, some reasone maybe , please check it one by one:
1. To check water sensor system if ok or damaged? Connect P & G, if working well, that means, the water sensor damaged.
2. To check the control box 6 terminal & 4 ternimal if any losen?
3. To check soft setting, if any wrong about power, if 0% or 0 power.
Hope you could tell me the answer after check .
Please be free to contact me direclty.
Email:[email protected]
Skype:sukelaser08
Mobile:0086-18668917435
Sherry
Quote:
Originally Posted by
t3v4
I bought recently chinese laser engraver IE1224 with 100W laser tube.
When I started machine, water pump works, air compressor works, vacuum motors works, x and y motor works too. But laser tube wont start.
Also on high voltage power suply i have some kind of test button which when pressed starts tube, and tube give light...
Can someone help me please?
