Need Postprocessor for Morbidelli author 503
Greetings all,
We have a morbidelli Author 503 Wood cnc.
It is shiped with Aspan 6.2 and running perfectly with the shiped cnc programs
Now we want to create some programs of our own and having a slight problem.
The CNC controller (tria ) understands only pgm files.
We bought Vcare so we could make some new drawings and cnc programs.
( we just dit not know that there needs to be a postprocessor, never heard of it )
Is there someone who has a postprocessor file in use with Vcare pro and wants to share it, so we can run our cnc ?
Geetings
Adriaan
Re: Need Postprocessor for Morbidelli author 503
can someone give me a help
my company hava a author morbideli 503,and we have a problem with him,they bought the machine in an unknown state,the machine was dead,I made software, and configure PLC,after that machine start the walk,but she doesent work anything,i made a program for driling in the software ASPAN but nothing happend,the machine show me on the monitor that everything is ok but doesent work,after that i see on the working head something missing, i dont know what,if someone had this machine maybe can tell me what is missing,i have 2 cable with 29 wire one with 17 and another with 12, and 4 el.ventils ,pleaseAttachment 255614 help,sory for bad englishAttachment 255612Attachment 255616
1 Attachment(s)
Can you help me, a need a picture of working head,from top side, i had the same machine,but my machine doesent work,yust walk,send me please picture of working head from top ,my machine has one part missing,i had 29 wires free and 4 el ventils
sory for bad englishAttachment 255626
I have sold my Morbidelli. It was A502 but very similar to A503. I think what you need are technical circuit drawings and these would most likely be held by a Morbidelli technician not an end user. I think you need more than just photos.
I take it that the 29 wires have been disconnected at the router head. Both the main router heads and also the drilling modules.
I also take it that the machine sizes OK.
If you create an Aspan program with just instructions to move (no routing or drilling) does the machine perform as per the program instructions?
I tried a private message to hasib-cnc but PM's disabled
regards
Greg
thans for the reply,do you have anything of this mashine, i dont have support from tehnician,and they dont want to came help,i dont know what to do,if i know how that look i can bought,anything is helpfull,please help,thanks
Hello Christopher,
I know this is an old post, but would you happen to have a copy of this " postprocessor SCM V1.7.3 " for a Morbidelli Author 213.?
My problem is that I canot generate a working .PGM file that the A213 can read. I keep getting the error" Invalid File Format".
I have searched all over the internet and nobody seems to be able to assist. I Also use Kermit to transfer files and it is quite simple to edit the DXF files in Alphacam.
Mat
HI Christoph, I have a A504 and use Winxoso to convert from sheetcam .txt file to pgm, I have the same firmware problem importing the file into the machine? did you manage to resolve it?
If I type it in it runs beautifully but automatic input not readable?
kind regards
Adrian
Hi Mat, did you win with the SCM v1.7.3 PP? I have the same problem, I use the Winxoso one but have a prolem with the Morbidelli reading it? It will run when typed in as is?
@Rocketworks
WinXISO does not seem to work for these old TRI7500 ... I use a very old converter called CNV75NEW.exe to convert my files from CAD/CAM to .PGM that this old NC can read
Send me you email address via pm then I'll send you the file
Thanks @auckcabs you're a star I got a copy of cnv75.exe from a forum member, mine is a 504 with Tria 7500 controller 1998. I'm using sheetcam with Xilog post processor is that correct? then what file extension do I use? do you mind sending me step by step instructions thanks [email protected]
Hi auckcabs, could you possibly send me on the CNV75NEW.exe. i have a 503 and need a program to convert cad to pgm. Would be really helping me out.
