1 Attachment(s)
SINO YAG 750W laser metal cutting machine
Attachment 242018
YAG 500W laser cutting machine,with 750W YAG laser power,it was suit for cuting metal sheet,such as stainless steel,solid steel,aluminum,copper,brass and so on.The cutting pression is very good,suit for accurate cutting works.
Applicable material:
Stainless steel, mild steel, carbon steel, , spring steel, alloy steel,iron, copper, brass, aluminium, titanium, metal sheets, metal plates, metal pipes, metal tubes, etc.
Applicable industry:
Sheet metal processing,metals ironware components and parts, chassis,racks & cabinets processing, kitchen ware, food machinery, cooking utensils, metal crafts, metal sign letters,elevator panel cutting,etc.
Main introduction:
1.Equipped with medium power lamp pump laser, flexible cutting any design within working area 1300mm*2500mm.
2.Suitable for thin metal plate specially large cutting, the processing speed is quick, the cutting precision is high, coordinate following dynamic focus system, it has realized different thickness materials automatic focus cutting.
3.The machine working table with ball units design for easier loading and unloading, it saved the manpower greatly.
4.It also can punching and cutting for metal pipe and tube if with integrated or detached rotary system.
Parameters:
Machine Model |
YAG steel laser cutter SN-750W |
Laser wavelength |
1064nm |
Laser pulse frequency |
0.1 - 500Hz |
Width of pulse |
0.2 - 20ms |
Working current |
100 - 400 A |
Laser rated power |
750W |
Laser power source |
18kw |
Chiller |
5kw |
Working size |
1300*2500*50mm |
Processing precision |
0.05mm/min |
Repositioning precision |
0.05mm/min |
Min line width |
0.2mm |
Located apparatus |
Red light direction |
Way of air protection |
Coaxial |
Suitable file format |
dxf, ai, plt |
Driving way |
Japanese servo motors |
Continuous working time |
24h |
Max cutting thickness |
(Carbon steel) 8mm |
General power |
12-20KW |
Electrical source voltage |
380V±10%/50Hz/100A |
Spare parts |
Xe lamp, water, auxiliary gas(N2, O2) |
Grade of laser |
Class IV |
Packaging size |
Machine:450*248*155cm
Control box:140*140*150cm
Chiller:130*120*150cm |
