4 Attachment(s)
Router 'lifts' on x-axis when moving
I had set up to plane a new spoil board I noticed that after I aligned the cutter to just touch the high point of the spoil board. Then I double checked it by running the x axis the full length its travel. What I saw was that when moving to the right the cutter just touched the spoil boar at it highest point, just as it should. However, when I moved the x axis to left the cutter was about 0.03125 higher than it was when moving to the right.
Any ideas or thoughts on what might be causing this? I have attached some picture of the axis to give a reference of what I have.
W
Re: Router 'lifts' on x-axis when moving
Take the tool out, unplug the router, and grab the collet and push and pull hard in all directions. Somewhere, something is loose and moving.
The pipes on the x axis are flexing quite a bit. I think the torque from the stepper may be causing the pipes to flex causing the deflection. I will need to add some supports between the pipes and anchor them to the back for support.
