HELP PLEASE!! setting up drip feed on tree dynapath delta 20 contol
Hi
We are currently running our mill out of memory but its now time to step it up to drip feed!!
Does anyone have a good software recommendation to install on or laptop ?? We use mastercam x5
to program with. Also is the pin config the same for our computer setup that we use to transfer
or will it be different for the drip? Our mill is a Tree Journeyman 350 with dynapath delta 20 control Any suggestions that pertain to what we
are attempting would be very helpful .
Thanks Guys Your Awesome!!!
DEANMACHINE
Re: HELP PLEASE!! setting up drip feed on tree dynapath delta 20 contol
Should be same cable. You will need to make sure Xon Xoff is set up on both ends. This is ASSUMING your machine has the buffered input option. You can check quickly by powering up the machine, before releasing estop or resetting i believe you press a softkey under the screen. The screen will flash what button to push, cant remember been 15 years.
Lots of software out there
DNC Precision Free Edition - Free download and software reviews - CNET Download.com
or whatever you using now might work.
