Fanuc 6 problem
Can anyone help me with the fanuc 6m??
I have this errors
600
603
607
This is appear on the CRT after I unplug the 6 wire connector that located on the power unit
So before I did that there was not anything appear on the CRT nothing powered up ..I don't know what I should be doing with these errors
Replace PCB master or pc model-b or mdi and crt or connection unit. ...Please someone help me
1 Attachment(s)
Re: Fanuc 6 problem
I can't help you but I can give you the Fanuc 6 alarm-list.
Heavy_Metal.
Re: Fanuc 6 problem
Thank you my sir Heavy_Metal .....I have the manual , maintenance , alarm list ... but I don't sure what I should be doing with these alarms (600 603 607) ....
600
Data transferring error took place in the connection unit or in PC-model B
603
The correspondence between NC and PC is incorrect or interrupted. Change power sequence control PCB or master PCB
607
Data transferring error took place in Fanuc MDI & CRT
Overheat alarm
... Please help me
Re: Fanuc 6 problem
Tell please me, what type PC-B or PC-G is used on your Fs6M?
Re: Fanuc 6 problem
Dear sir,
It's Fanuc 6M-B
PC-B
Re: Fanuc 6 problem
Your three errors can be by following reasons:
- not set paramettr N003 bit #7;
- is bad pc-b A20B-0008-0440 system or Ladder ROMs;
- not connect or bad serial I/O cable (DIO to MB);
- is bad pc-b A20B-0008-0440 PCB.
Necessary to check all this.
Re: Fanuc 6 problem
Dear sir ,
I did checking hardware for PC model- B, nothing was wrong , so how I can do checking software for it
Re: Fanuc 6 problem
double check you didnt knock a plug loose- the DIO cable goes from master to connection unit1 (if you have stacked IO boards, it then loops to the back one) and from connection unit to MDI keyboard connector, then either a terminator plug, or another loop out to op panel IO (last serial device has to have terminator plug). the rear connection unit (if there) is kinda hard to see- make sure the honda plugs are seated- those are the rectangular ones without screws, just clips...they coulda been dislodged when unplugging other stuff if the cables are bundled/tied...
Re: Fanuc 6 problem
If software of the PC-B is Ok, that you have possibility to enter the PC parameters.
Re: Fanuc 6 problem
Yes I can enter the parameters list.. .so
.how much percentage (probability) that can you give me it to replace the master PCB ??
Re: Fanuc 6 problem
Main Board you can check so: Set the parameter N003 bit #7 to 0. All your errors must be lost.
Re: Fanuc 6 problem
Ok, I will check that. ..thanks alot .
1 Attachment(s)
Re: Fanuc 6 problem
Attachment 255296
I can't switch MDI mode on
On the other hand, power off lamp is light
Re: Fanuc 6 problem
For write CNC parameters in Not Ready state you need following:
- Press button "Emergency Stop";
- Switch "Parameter Write" on MB to "Enable";
- Enter selected parameters.
Re: Fanuc 6 problem
My dear agering
Does you mean changing 10011000 to 00011000 ?
Re: Fanuc 6 problem
Yes, it is necessary to change.
Re: Fanuc 6 problem
Dear agering
I did all things that u tell me ... I can't change any parameter. ...do u have any idea about that?
Re: Fanuc 6 problem
It is Necessary to check all connections, cable and power voltages to MDI&Connection Units. If you need Maintenance manual or other information tell please me your e-mail.
Re: Fanuc 6 problem
Dear agering
That's my email [email protected]
I will be thankful and appreciative
Re: Fanuc 6 problem
fanuc 6m-b problem
I have centrum 1000 fanuc 6m-b cnc turret punch ..I have problem with it.... alarm message on the CRT display when I power up it ...I think that the ex worker who was working on it changed something (software or hardware) on it ...However I don't have the electrical connection manual ... I think that if I have other machine like it , I will make helpful comparison between those. ...
Alarm 600
Alarm 603
Alarm 607
Anyone have the same machine can help me
Any help I would be greatly appreciate. ...
