Powermax 45 intermittent arc loss
Hi Guys,
I'm running a powermax 45 on a custom built table using candcnc dthc2 electronics, mach3 software. I'm having an intermittent problem with loosing the arc sometimes whilst cutting. Here's what happens: I can be cutting some parts fine and then when cutting 1 part the torch will loose arc whilst still in motion, re-fire and complete the cut. This is obviously highly annoying as it messes up the part. I tend to find that the thicker the material or the longer the cut the more likely I am to experience this problem... I'm wondering if this is an air issue?? I'm just using a crappy inline moisture filter until I get my drier plumbed in. Is this likely to be the cause, or is there something else I should be looking for?
Re: Powermax 45 intermittent arc loss
Hi Adam, did you ever get to the bottom of that fault? I still get it on the odd occasion.
This issue is covered in depth on the CandCNC Support Forum where there are hundreds of CandCNC users with Hypertherm machines.
TOMcaudle
www.CandCNC.com
Hi, Yes I did finally solve the problem and it turned out to be a PC issue. Once I changed over to a Dell Optiplex 745 the issue was resolved. I now run at 48khz kernel speed in mach with re reoccurrence of the original fault.
Just a word of advice.... make sure to backup the latest xml file for the screenset you use in mach. My hdd failed a few weeks ago and it caused me a world of pain going through the setup again!!!
