GE Fanuc 0-M series parameters required urgently
Good afternoon all,
I have a Cincinati Milacron Sabre 750 mill with GE Fanuc 0-M panel.
Someone has deleted the entire memory along with all the parameters.
I am completely new to this machine and have no reading material or manuals for reference
Would someone kindly be able to send me either a pdf. manual with the values which i can punch in by hand or, a file compatible to send via RS232 ?
Many many thanks in advance.
Dale
Re: GE Fanuc 0-M series parameters required urgently
your parameters doesn't include the 900s
Quote:
Originally Posted by
HASSIA
Proprietary information
Unless these option params are for a very similar machine, activating the wrong option can cause serious problems.
2 Attachment(s)
Thanks faiz!!, the main problem that I got when put the wrong parameters was...
Attachment 239754
Attachment 239756
I'm looking fot the supermax max 3 (YMC-VMC-72A) WITH A FANUC 0M CONTROL parameters
You should first enter all 900 params (options), cycle control power and then enter the other params and diagnostics.
hello faiz how r u i am zain ali from Pakistan and i am doing troubleshooting of cnc machine in Lahore.id is [email protected]
cell number is +92-332-4244023..please contact.
greetings to you faiz . this parameters are of FANUC O-M but is O-MC ? or other
That was 5 months ago, hopefully he has by now!!
Al.
Hello,
Need help with old Fanuc O-M. (Supermax YCM-VMC-72A)
I lost parameters (I think battery problems). I put parameters manually, looks ok, but found same different.
1. I cant write programs in memory (appears alarm 086). Programs in memory 0, but memory are full.
2. Do not switch gear box to second gear. (2 gears box.)
3. Not very big problem: Zero return all axes works when hold the button (before was automatically by pressing once)
Maybe I do not write good parameters or write not all (cant reach parameters from 10300 to 10499)
Maybe someone have the same machine and I can check parameters with good one.
Thanks for some ideas,
