3 Attachment(s)
Homing.. need help please
I have done both upgrades to the machine, as well as changed PC's. But I kept my profile, so I am not sure why this isn't working, as it used to before the changes:
When I home, the axis moves in the correct direction until the limit switch is activated. But they won't retract off the switch. Here are my screen shots:
Attachment 250066
Attachment 250068
Attachment 250070
Can someone please tell me what I've done wrong.
Ray
Re: Homing.. need help please
What happens? Do the axis labels turn green to show them homed? Or do you get a limit switch error?
Gerry,
I am actually using your 2010 screen, so I don't know. I am using these switches
Hall Effect Sensor Module from nicegear - New Zealand's open source and VoIP hardware specialist
They have a LED on board so I know they are working.
I get a limit switch error in Mach. It won't back off the switch, and I can't cancel it with a reset. So I can't back it off manually either.
Any help would really be appreciated.
Ray
Try setting a debounce of around 5000, and see if it helps. If it does, then you're getting noise on the switch lines, or your switches are triggering again as they are backing off the switch.
Thanks Gerry, I will try that tonight.
Ray
