HAAS UMC 750 Vs Mazak Variaxis 500
Will the New UMC 750 run circles around a Mazak Variaxis 500? Currently in the Market for a 5 axis machine and the Haas looks impressive but no experience with the has trunnion style machine. Can you get pretty aggressive milling with a trunnion setup or is it a lot less rigid the VF3 with a vise mounted on table? And if so, how aggressive will the trunnion handle?
Thanks in Advance!!
Re: HAAS UMC 750 Vs Mazak Variaxis 500
I have experience with the Matsuura MX-520 and surprised there is no discussion about this machine? The industry should educate themselves on what true 5-Axis machining is about but please stop and take a close look at the machine design, the trunion, kitematics, bearing sizes, spindle design/torque, positional and repeatability accuracies . . .
Compare the UMC-750 spec to the MX-520. There is a difference and for a reason.
DMG MORI DMU MonoBlock and DuoBlock Series is the premier platform for 5 axis machine. When it comes to 5 axis machining, Siemens has no equal in speed, accuracy, or surface finish.
