GWK 1325 CNC metal laser cutting machine
The advantages of cnc metal laser cutter:
1,Imported linear guiding system 25mm, with strong carrying capacity, stable running, high precision, and longlife.
2,Z-axis adopt imported ballscrew, equip with standard lubricating oil system, which ensure the machine last longer.
3,Selecting hih-power water-cooled motor and high-performance frequency converter, make machine with good performance, big torque, high efficiency.
4,Softwar with best compacity compatible with Type3/Artcam/CAXA/UG/Pro- E/Mastercam/Artgrave,etc.
samples:
http://www.alibaba.com/product-detai...015029381.html
For more information,pls remember following info:
Skype: Angela Jinan
Contact: Ms. Angela
msn: [email protected]
Technology Parameter
Specification |
X,Y axis working area |
1,300*2,500mm |
Z axis working area |
<200mm |
Table size |
1,450mm*2,920mm |
Max. speed |
0-30,000mm/min |
Max. Working speed |
0-20,000mm/min |
Working delicacy |
0.02mm |
Reposition accuracy |
0.05mm |
Max. Feeding height |
200mm |
Command |
G code *.u00 *.mmg *.plt*.nc |
Software |
Type3 ,Artcut,Artcam,Ncstudio software. |
Max. power consumption |
5.5kw |
Work type |
stepper(option: servo) |
Spindle speed |
24,000rpm |
Memory |
32M |
Working voltage |
AC 220V/380V,50/60Hz |
Manner of receiving data |
USB or PCI |
Running circumstance temperature |
0-45 degree |
Relative humidity |
30%-75% |
Weight |
1000kg |
