Cannot Set Stock
Im using Solidworks 2013 with Camworks 2012 and have a new issue. When I go to the Camworks feature tree and edit my machine, that works ok so I know its found the Tech DB ok, however when I go to modify the stock I get no pop up window and all the Camworks features grey out. I know the licence is good and can see that in the licence manager. All the Camworks features are there until I right click to modify the stock. Any thoughts ?
Re: Cannot Set Stock
Have you had a dual monitor on there at all?
The dialogue may be on the other screen still....
I have tried with both dual monitor and rebooting with only a single monitor, im convinced the window is open somewhere as I can do nothing when it happens, pressing escape closes the window I cant see and then I can carry out other functions again
Camworks does have a toolbar reset tool I'm not sure if it will help though in this case,
It's in the camworks folder from the start menu, alternatively just reinstall the service pack.
Your reseller may be able to help you too.
Tried it this morning with the original dual screen set up and up popped the stock manager window. Don't know why it did not appear on the second screen that I was using at home. I had gone through the detect screen process correctly before connecting and after disconnecting the screens. Thanks James for your suggestions
