How to transform a G code into a XYZ position?
Hello friends!
I am having some trouble and I am sure you guys can help me. I need to transform a G code in a XYZ position. I am using Altair Hypermesh to simulate a stamping process. I am using a CAM software to generate the tool's tragetory on G code but I need to transfor G code into XYZ positiom so Hypermesh can understand the path tool need to follow.
For exemplo
I have a G code like this:
S8000 M3 M43
G0 X261.607 Y238.825
G43 Z5.0 W0.0 H00 M8
G94 G1 X251.367 Y251.119 Z-5.0 B0.0 F800.0
G17 G3 X248.913 Y251.393 R1.767
X248.581 Y248.947 R1.767
X250.023 Y248.232 R1.769
X253.842 Y251.908 R3.767
X250.205 Y255.764 R3.767
X244.238 Y250.241 R5.767
X249.724 Y244.239 R5.767
X250.547 Y244.245 R8.472
and I need to have a XYZ position like that:
t x y z
0.006 -39.1422359731 -74.0404497176 0.04
0.009 -25.6389770165 -79.7292022342 0.04
0.012 -9.2789593029 -83.2346306871 0.04
0.015 7.5053535083 -83.4132633343 0.04
0.018 24.9806024949 -79.9379279838 0.04
0.021 39.7506629673 -73.7155860386 0.04
0.024 51.2709784039 -66.222274235 0.04
0.027 63.844394138 -54.2032855877 0.04
0.033 80.0233623289 -24.7055522692 0.04
0.036 83.3545522634 -8.1315095973 0.04
0.039 83.2917282148 8.7516194127 0.04
0.042 79.6309342907 25.9425737995 0.04
0.045 73.2164700281 40.6626529875 0.04
0.048 63.0382654284 55.1387334198 0.04
0.051 53.1713724693 64.7063210288 0.04
0.054 41.3274655886 72.8432798505 0.04
Do you guys some settings or programs that can do this?
Thank you so much!
Re: How to transform a G code into a XYZ position?
if you know python or similar writ ran converter would be fastest to do so
Quote:
Originally Posted by
Tkamsker
Hello friend! Could you explain your idea to me?
thank you
yes write a lttlle Python ( there are a lot of examples ) or any other programming language you like
software which reads your g code file
and produces the file you need if you have an experienced basic programmer probably an access macro could also do the trick
thomas
Rusty thats what i meant ..
