Any tsugami users have problems with sub collet sticking? Chuck completely disassembled toggles and all, no chips or contamination. Machine only month old
Printable View
this issue troubles me too, finally find a solution. you need to make a gasket almost 3~6mm thick,put it between the collet support and the tube, everythins just fine. the tsugami agent told this is a comman issue with lot machines. wish helps.
