Problem with laser machine
Hi
I have a redsail 50w laser machine that has stopped working , basically we had a power cut and the main fuse box tripped out, Everything else turned back on ok but the laser machine didn't .
I have bought a new power supply today and changed it over but it still doesn't work,
any ideas what else it could be?
thanks chris
Re: Problem with laser machine
Hello chris, do you have a water chiller to protect the machine? as you said you had a power cut, so I think you should lower the power or you can choose a larger power laser tube.
Hi Chris,
here is some of our problem test video, hope can help you
GWEIKE LASER - YouTube
YouTube
Quote:
Originally Posted by
cdfracing
Hi
thanks chris
Hello
thanks for the video, but there is no power to the machine at all,. it's like it doesn't have a power supply fitted .
we had a power cut that tripped out all our machines, which came back on except the laser machine
Have you bypassed the emergency Off switch.. Mine just all of a sudden broke, shutting it all down.
