Re: MHackney's G0602 build
Looks good! What is that tool cabinet you are using for a stand? I am looking for a stand for my G0602 which is CNC'd also using Billy's kit.
I used a Harbor Freight 44" cabinet that I got on sale. It is a really nicely constructed unit actually. Right now I have it on the rollers so I can move the lathe around (to access the back of my G0704). It is a little tall. I am going to position the CNC lathe permanently on the other side of my shop and remove the casters so the the lathe will be about 5" lower. That will be perfect. I can mount the electronics on the cabinet side and I'm considering and all-in-one PC with touch screen mounted on an arm so things will be nice and compact.
Cheers,
Michael
Looking forward to this:)
Thanks Michael.
Is that stand sturdy enough on the casters for the lathe? I actually like the idea of being able to move it around, I have a small shop and portability is a premium.
Yes it is. The casters at the handle end lock, the other end are fixed. I lock them and have had not problem with movement. I did put a piece of 3/4 plywood on the top with formica surface to sit the path on. I don't even have it bolted down right now! I plan to make a pan for chips and catch mist coolant as part of this conversion.
Cheers,
Michael
Quote:
Originally Posted by
mhackney
Cheers,
Michael
Awesome! Thanks, I am definitely going to get one of those.
Well, it turns out the Keling drivers have are not compatible with the KFlop - they requite of their 5us Direction Setup Time requirement. So rather than mess around, I returned the drivers and ordered the KStep. It plugs right into KFlop and provides 4 drivers. Compared to the compatible Gecko drives, it is actually cheaper, more convenient and gives me 2 extra drives to mess around with.
I completed my manual lathe job this weekend so I am starting to tear down the lathe tonight for the conversion.
cheers,
Michael
23 Attachment(s)
Ok, I started the teardown and cleanup. It took something like 45 minutes to clean the swarf, oil, grime off the lathe and stand. I removed the tailstock and dug in using Billy's instructions that he emailed with the kit. Total time to disassemble was less than 30 minutes!
Cleaned up and ready to tear down:
Attachment 252388
Attachment 252390
Attachment 252394
Attachment 252396
Attachment 252398
Attachment 252392
Attachment 252400
Attachment 252402
Attachment 252404
Attachment 252406
Attachment 252408
Attachment 252410
Attachment 252412
Attachment 252414
Attachment 252416
Attachment 252418
Attachment 252420
Attachment 252422
Attachment 252424
Attachment 252426
And that was the basic tear down! While I'm in there, I want to take a look at my gibs and try to figure out the leadscrew tell-tsale problem I've had (the lead screw leaves an obvious spiral on the part under some circumstances).
Attachment 252428
Attachment 252430
This seems to be the culprit, it was not adjusted properly allowing the saddle to lift up and down. I tried to adjust it to no avail. I need to look at the manual to figure out how it is supposed to work.
Attachment 252432
Just looked at the manual, that part is called a saddle clamp plate and it is not mentioned anywhere! Just listed in the parts diagram. Anyone know how to adjust it properly?
Edit AH! this is the saddle lock and should be loose when not locking the saddle. It was the other strip in the second to last photo above that was not screwed in all the way either and allowing saddle lift. Now properly tightened, the saddle slides smoothly and does not lift.
MIchael,
That is used to lock the saddle in a fixed position, usually for facing or parting.
Ray L.
Thanks Ray, yeah, I edited my post above - I figured it out. Makes sense now. I had an Allen wrench epoxied in the screw head for the lock so once I removed the Allen, I lost track of what it was!
By the way Ray, the KStep I ordered Friday came in yesterday, talk about fast. It mounts easily to the KFlop and should be easy to interface. I'm glad I went this route, it will be a clean electronics cabinet.
mhackney
Michael,
Cool!. Post a picture!
Ray L.
4 Attachment(s)
Got the mechanicals (Billy's kit) mounted tonight. Even with the little extra work I did to cleanup and adjust the cross slide gib it was a 45 minute job start to finish. The only tricky part was removing the original Z screw coupler. I was able to drive the pin out with a 3/16" rod and a small hammer.
Attachment 252556
Attachment 252558
Attachment 252554
Before I tighten everything I want to install these bellows screw covers on the Z ball screw.
Attachment 252560
Looking great, Michael, following the build, thanks for doing this.
Where did you pickup those bellows?
Dave
Hi Dave, I got these on eBay
Pretty nice units and a great price.
Ray, not much to see but here is the KStep docked to the KFlop:
http://www.cnczone.com/forums/attach...2&d=1412859549
With the mechanical assembly done, I'm putting together the electronics. I'm going to lay it out on a board to get things to work and figure out how to lay out my box.
Cheers,
Michael
mhackney
eBay
Nice find, thank you sir-
Dave
3 Attachment(s)
Got this little slotted table from LittleMachineShop. It's 1" thick. Just playing around and maybe use it on the lathe.
Attachment 252982
Attachment 252984
I also took out the gears to the Z screw feed:
Attachment 252986
and I printed a couple of Hoss' nifty stepper covers. They are taped on until my 3mm x 30mm screws come in to attach them properly. It was pretty easy removing the long screws and grinding them down as per Hoss' instructions. I wasn't able to get the screws out of the steppers on my G0704 so I haven't been able to install these covers on that machine yet.
Now I'm wiring on mounts for the bellows to protect the Z ballscrew. Ordered some 2" OD 3/8" wall aluminum tubing. The ID of the bellows is right at 2". I plan to cut a slice about 1.25" long, drill 3 holes through spaced 120° so I can screw it to the apron on one side and the lathe on the other. Should work, I'll post photos when done.
I've also been making progress on the electronics. I am configuring my KFlop with the KStep. It is pretty straight forward to do the configuration and upload it. The KFlop-KStep combo is nice and compact and provides all of the I/O I need for home switches, spindle speed control, spindle index, etc. I have a metal cabinet ready to start mounting the electronics. I haven't been able to wire up the steppers yet as I don't have any 18 gauge 4 conductor cable. I thought I had some extra but it was 22 gauge.
cheers,
Michael
