How to use G143 tool length compensation on a HAAS VR-11
We have two HAAS VR-11's and we use Surfcam as our programming software. Surfcam puts out 5 axis code where some toolpaths have a G143. If I understand it correctly this function gives you the ability to not have to enter gauge lengths in the software. I for the life of me cannot figure out how to get this to quite work correctly. Currently I must edit the G143's to G43's and enter gauge lengths in the software. H offsets are set 1" off the table with a 1-2-3 block and are entered as a negative number. Then the Z origin is set with a shift in the work coordinate, example: If Z0 it 4" above table, then Z3.0 would be in G54. Then when 5 axis code is run, the gauge lengths are entered in the software, and the pivot length is entered in the post processor. Then the g/l's must be entered in the control as a negative number, I happen to enter them in the wear column, and the pivot length must also be entered as a negative number, I subtract it from the Z in G54. Does anyone know how to make G143's work?
Thanks, Mike.
Re: How to use G143 tool length compensation on a HAAS VR-11
just saw this - have you figured it out?
vettespeed
Are you doing 5 axes machined parts, or just 3 axes parts, if you are doing 3 axes parts, you should get the right post processor, The way you are doing your setup, is a crash waiting to happen
