Master the Advantages of Ring Die Pellet Mill
Ring die pellet machine is also called ring die pellet mill, which is the core equipment in pellet manufacturing industry. This pellet mill usually applies to big sized production and big output per hour. The output of ring die wood pellet mill is about 800 kilo to 20 ton. Ring die pellet mills are of vertical structure and they combine with the flat die pellet mills’ vertical feeding method. And you must consider the place you need the wood pellet mill, if you have a big area, ring die pellet mills will provide you big production. Otherwise, small pellet mills are space-saved. The output of ring die wood pellet mill is about 800 kilo to 20 ton.
1. The speed of the feeder can be controlled to meet different output requirements and with the special structure, it makes materials convey evenly.
2. With international advanced equipment and technology, Stainless ring die has long service life and can make pellets with high quality.
3. It can adapt to a variety of biomass feedstock, the material from powder to the length of 50mm with water content of 10-25% can mold.
4. It is widely used to make pellets from light substance,such as wood chips,sawdust,straw,grass,rice husk,pasture,palm leaf etc.
5. With new designed iron removal device and overload protection system, which can protect the machine well during production.
6. Our product with high automation which can save labor,and it is also easy to maintenance ,save a lot of maintenance time.
7. Long history in wood pellet machine and biofuel briquette machine making,has exported to many countries.
8. The imported bearing and oil seal in the main drive ensure high efficiency, stability and durability.
9. Coupling assembly: with hub-taper lock bores, bushing-taper locks, S-shaped grid cover etc.
If you are interested in pelletizing machine for sale, welcome to contact or visit Fote Machinery: [email protected].
