Re: Spindle Motor Encoder
Looks like a pretty decent motor, 4 pole inverter rated motor by the look of it.
If you intend using the encoder, you will need a VFD with encoder or P.G. option fitted.
Mach 3 cannot accept encoder feedback for motors.
Al.
Thanks for the response. I had planned on using teco jnev-202-h1. Is there something I would need to add on in order for this to work?
That model does not appear to support an P.G. or encoder option.
Normally you need to order this when purchasing, if the option is offered.
Al.
OK thanks for the info. I canceled my order and went with a regular inverter duty motor without encoder.
If anyone is interested in the Marathon Max+ with encoder, these guys have the best price by far:
http://dealerselectric.com/Y284.asp
