How to reduce noise in Control Electronics
Dear Sirs,
We have got Siemens 802D SL CNC controller wherein axis movement is erratic
Like we got a 2 axes Turing machine v replaced ballscrew, end support bearings, external encoder on the shaft of ballscrew, lubrictation is ok still suddely we find vertical axis has come down by 150 microns causing scrap. When we check repeatability of axis by using dial in Automatic program for 50 cycles, we find it to be ok and repeating but only during cutting, suddenly X comes down
We also checked alignment between self centering chuck center and tailstock
Please let us know what needs to be done to ensure there are no noises in Control Electronics
Is there any way to check/measure Electronics noise which can move axis (like drift) due to which machine not be moving as per command from CNC
Warm Regards,
