I have a Boy 15s injection molding machine. I added a PLC and I am manually going through the movements at this time. However, I cannot get the screw to retract. It will rotate fine and hot plastic will extrude out of the tip. There are 10 solenoids on this machine. I have added 10 buttons to activate each solenoid regardless of the limit switches. s3 will push the screw into the barrel. s17 and b18 cause no motion but I believe b18 will drop the injection pressure. I can hear the solenoids click when activated. Any help would be appreciated. Thank you in advance.
graemeian
