FANUC AC MAIN SPINDLE problem!!
Hello all.
We have FANUC AC regulator for main spindle type A06B-6059-K0311.
On display we have error message AL-17.
Regulator has display on main board and 4 buttons
MODE UP
DATA_SET DOWN
We have checked all voltages (+24; +15; -15 and 5 V) are they are ok.
Could anybody tell us what is ALARM-17.
How to enter parameters and listing of parameters.
Best regards !
Fanuc Spindle Parameters and description
So these are the parameters for main spindle on A06B-6059-K0311.
Parameter- Data- Description
F00 0 Speed motor is dispayed
F01 0 Signal (MRDY) is used
F02 0 Use/No used speed override
F03 0 Range of speeed override
F04 0
F05 1 Maximum speed
F06 3 Output limit pattern
F07 100 Limit output value
F08 5 Delay time to motor inter.
F09 0 Use/No use mrdy signal
F10 124 Error offset in CW (SRF)
F11 147 Error offset in CCW (SRV)
F12 128 Offset in orien. (ORCM)
F13 34 Adjust speed in CW (SRF)
F14 34 Adjust speed in CCW (SRV)
F15 50 Speed with 10 Vs
F16 15 Detec. Range speed (SAR)
F17 3 Detec. Range speed (SDT)
F18 50 Torque limit value (TLMH)
F19 10 Aceleration/Deceleration time
F20 40 Limit regenerative power
F21 50 Velo. Loop gain high gear
F22 50 Velo. Loop gain low gear
F23 100 Velo. Loop gain orient h.g.
F24 100 Velo. Loop gain orient l.g.
F25 30 Velo. Loop gain h.g.
F26 30 Velo. Loop gain l.g.
F27 30 Velo. Loop gain orient h.g.
F28 30 Velo. Loop gain orient h..g.
F29 160 Speed offset (Test TS3)
F30 0 Motor speed indication
F31 1 Rigid tap mode (TLML)
F32 10 Motor voltage normal operat.
F33 10 Motor voltage in orientation
F34 100 Motor voltage in rigid tap
F35 75 Detection R.P.M. N=0 signal
F36 70 Detection range load
F37 0 Time constant torque deceleration start
F38 0 Control deceleration
F39 0 Control stable rotation with no load
F40 0 Control in torque limitation
PARAMETERS WITH STANDARD VALUE:
Parameter Data Description
F41 64 Current loop gain
F42 10 Slip compen. con.
F43 16 Slip constant
F44 10 Voltage compens.
F45 5 Max. amplitude
F46 30 Second. cur. const
F47 8 Cur. estimat. const
F48 71 Const. torque point
F49 56 Excit. weaken. point
F50 73 Volt. conv. const.
F51 2 Gear 128=1 255=2
F52 127 Cur.Conver. Const
F53 11 Curren loop P gain
These Parameters are from tabele. This motor type is 8S and there is 6S, 12S, 15S, 18S, 8P, 12P, 15P, 18P, 22P, 30P, 40P.
Re: FANUC AC MAIN SPINDLE problem!!
Thank u Duke for posting this info. But need further more assistance from you. When i tried to initialize the NVRAM...upto stage 7its OK with me. but when i tried stage 8 i.e holding and pressing data set button it never came in "Good" condtion even i waited long time. Insted of that it flashes AL-17. Even when i tried to insert parameter it not showing the parameter values.
pls post on this as soon as possible.
Dear Guhl,
where can I find the FF parameter? Is in the Yaskawa A1000?
I want to turn the rigid tapping on. Landsides said turn FF31 to 1 but I do not know how to change this parameter.
Thanks very much for your help!
Hung
Quote:
Originally Posted by
KQHung
Dear Guhl,
Hung
may be they mean option parameter in CNC. what's your controller?
guhl
My controller is Fanuc OM-B.
