2 Attachment(s)
help:alarm 480&487 for emco maxxturn 65 fanuc 18i
hi i no this is dump but i have to ask
i just moved to another cnc workshop and while starting up this machine and then referenced all axis i switched off the machine
now the machine cannot go to referance place because it is there
and the alarm displayed is 480 and 487 as listed in images
so the question is
how to move the machine manually to re-referance the axis
Re: help:alarm 480&487 for emco maxxturn 65 fanuc 18i
Hello,
I just ran in to the same issue, when for some reason the x-axis was able to move way up but did not respond when I tried to jog it the other way.
I also had the 410 alarm before.
How did you overcome these errors eventually, assuming you found it?
Thanks in advance
