CAD drawings of most popular V8 engine bellhousing patterns
Hi
Does anyone have CAD drawings of most popular engine bell housing patterns that you wouldn't mind sharing
Ford Modular V8 bellhousing patterns detailed drawings or dimensions ?
Ford 460 big Block ?
Ford 351 cleveland ?
chevrolet big block / small block ?
chrysler big block / small block ?
Even raw G-code would be fine.
would be greatly appreciated
cheers
chevy bell drawing pattern
hi, have chevy SB,BB drawings. will send to your email - just send me a link. radim [email protected]
p.s. have you found mopar bell pattern ? i can not find it anywhere .... thanks ....
I have some Mopar drawings
I have both the small and big block Chrysler bellhousing drawings, plus the slant 6.
I also have a really fuzzy photo of an AMC V8 blueprint, but it is readable!
I also have some nice drawings of 4 and 5 cylinder Volkswagen TDI Diesels.
PM me your email address and I'll send them to anyone who wants them, I'm not interested it setting up a photo hosting account.
Lastly I'm searching for a BOP Buick/Olds/Pontiac/Cadillac bellhousing bolt pattern drawing.
P.S. I have a spread sheet listing a pattern for the Mercedes OM617 5 cylinder Diesel
1 Attachment(s)
Slant 6 Bellhousing Bolt Pattern
Small block Chevy Block Front
I am in dire need of the location of all the holes in the front of a Small Block Chevy.
Any help would be great,,,,,,
thanks.
bell housing and motor pattern needed
I would greatly appreciate any drawings showing dimensions for a 3800v6 chevy or a 4l80E transmission. I want to make an adapter plate to pu the two together.
2 Attachment(s)
Mopar Bell Housings Patterns
Searching: BMW 4-cylinder DIESEL (320d) bellhousing bolt pattern CAD
Hi Guys,
I am looking for the BMW 4-cylinder DIESEL bellhousing bolt pattern CAD drawing, or print.
Model: E 46
Engine: 320d
I plan to connect a Chevy Small-Block (Gen. I = up to 1085) with a BMW 6-Speed-transmission by using a adapterplate.
So I´am looking for a CAD drawing of the Chevy bellhousing bolt plattern too. I´ve found already a picture here, but would apreceate if someone could send other/more drawings.
I´am not so mad to hope, that some had already build such a adapter plate, but if -- that would be GREAT to get the used CAD-file.
Sebastian
Mopar 318 Bellhousing Dimensions
Quote:
Originally Posted by
monc440
Found these yesterday.
That first drawing that your posted a while back isn't quite correct. While the bolt holes dimension locations are correct, the drawing of the bellhousing is tilted upward. Can someone who has an actual Mopar bellhousing draw the bellhousing the correct way to dimension from? :)
Thank you,
David
Need 518/46 RH bolt pattern
I am trying to marry a 440 to the 518/46RH trans and need the bell housing of the trans bolt pattern if available. Thank you!
a bit OT, need bolt pattern for 331 hemi crank flange
I'm looking for the bolt pattern / size for a 331 Hemi Crankshaft Flange
After looking online, I find that there's an 8-hole pattern and that there is 1 hole offset.....but can't find what it is that makes the hole offset (is it an angular difference? or radial difference?);
nor the basic H.C.
