Problems connecting to viper 200 drive
My flame table has been working for several years using the Viper 200 drives, I needed to change out some Thompson dura true gear heads, so I need to re tune the drives.
The problem is I cant get them to connect to my laptop. This is the same laptop I used to program the drives 2-3 years ago. I am also using the same USB to serial converter. I have also tried another laptop, and a second USB to serial adapter.
I was looking through the manual, and found the part about the jumper setting. Do I need to install a jumper on the 1st pin settings? I cant remember.
any Ideas?
I need to get this working, I have some plate to cut.
Steve
Re: Problems connecting to viper 200 drive
The jumpers don't have anything to do with the serial connection. Check that the 5 pin connector pins havn't got dirty .,maybe wipe them with some alcohol.
I think you have the V200F so It is probably 38400 baud.
Larry
I finally gave up on trying to get my laptops to work with tuning the drives.
I connected to a serial port using my desk top, and it works. I can read , write, and exercise the drives.
I tried to download the manual to tune the drives from the website, but it was not working.
I am using 850 in oz servos that are connected to 5 to 1 dura true gearboxes. Any suggestion on where to start on the tuning?
Steve
I use the same motor on our 4'x 8' router but the tuning is a bit different since i'm using a timingbelt reduction and not a gearhead.
But bank 3 is pre-programmed for that motor.
P575
I4
D 975
L4
R450
F500
I'm running 45 volts so depending on what PS voltage you are running you will need to change the P and D settings (reduce for higher voltage)
What tuning were you running ?
Larry
Larry, I am running 80 volts.
I was using a 30 to 1 gearhead, but it had too much torque. That is why I changed.
I worked on the flame table for about an hour today. I was happy that I could read out the setting, and exercise the drives. I could not play with it too long, I had to go to my day job.
I will try it tomorrow.
How much should I reduce the p and d?
Steve
Larry-
I installed the parameters that you suggested.
Now on the x axis (2 servos x and a) when I try to move the the axis it faults. The error led flashes 4 times (low voltages). The other drive is fine.
I switched the incoming voltage (80.0 volts). Just to rule that out.
My gantry is heavy, but it moves easily.
Any suggestion?
Steve
Hmm, did it work before on the machine with the same powersupply ?
Does it produce the 4 error right away ? or when you try to move it. Are you sure its flashing a consistant 4 flashes over and over ?
Try switching the drive to a different axis to see it the problem follows
Larry
Larry, I have always had problems with the x-a axis.
The x-a axis was working kinda before I switched out the gearheads. I went from 30 to 1 to the 5 to 1.
I have the jumper set to bank 1.
Tomorrow I will switch the x and a drives and let you know what happens
Steve
It flashes the 4 code when I try to move it. After about 3-5 inches of movement or when I change direction it faults.
When I use the viper tune should the current setting be 30 or 153 ?
Larry-
I finally got some free time and I swapped the drive. Here is what I did.
1st switched the output and encoder cable. Tried to move and faulted. 4 flashes
2nd. Switched incoming 80 Vdc. Also faulted. 4 flashes
Could a setting cause this or is the drive bad?
Steve
A low voltage fault (4 flashes) happens if the drive see's under 65 volts.
Is it a switching PS or linear ? Was it running before with the same PS ?
A setting shouldn't cause 4 flashes. Does the drive hold, when fault when you try to move ?
Larry
Larry
The power supply is a linear power supply. The table was running, and just started faulting. At first I thought the gear box was bad. I changed the gearheads. That is when I noticed the flashing faults.
I will have to check to see if it holds when faulted. Can I send you the drive for repair, or do I need to buy a new one?
Steve
So just 1 drive is giving problems, and you swapped the drive and the problem followed the drive ?
Your sure its 4 flashes and not 5 eh? If its 5 then it could be an encoder noise problem.
(no it won't hold if its faulted, i meant before it faults )
Yes if you think its a bad drive and the other one works in its place, then send it back (always by mail, not courier)
Larry
Larry
The problem followed the drive.
I had my wife ship the drive to you. You should have it in a few days
Steve
Larry
Did my servo get to you?
Steve
Yes, i got it on thursday.
Hmm... did you realize the the fuse was blown ? ( Thats why it showed 4 flashes. )
I put a new fuse and it works ok.
Was this drive also tripping out easy ? The overcurrent seems sensitive, i will check that out.
Larry
No . I never checked the fuse. I thought that since it had power on the LEDs the fuse was good. If no LEDs would illuminate the I would have checked the fuse.
The tripping out is one of the main problems.
Steve
Quote:
Originally Posted by
Scrambled1
The drive has 2 sides. The main power and control side are opto isolated. ( This lets the RS232 and Encoder grounds have no connection to the 170 volt for safety. )
The control side with the Led's is powered by the 15 volt and isn't fused. The main Highpower side is the fused side, and has no led's. The 4 flashes (under voltage) indicates that there is no voltage or low voltage on the main side.
Larry
Any reason you did not add a led "power " lamp ? Have you ever looked at the fuze holders that have a let illuminate when the fuze blows? Just curious ?
Steve
Larry-
The servo drive arrived today. I reinstalled it today and That drive appears to be working . After the gantry moves about 20 inches, the other x axis drive faults. The error is over current (6 led flashes). This should be from bad tuning? Correct?
Should I copy the settings in the returned/repaired drive into the one that is faulting?
Steve
I presume are talking about having a servo on each end of the gantry ?
Is that a rapid or slow move that it faults on at 20" ? Try a slow jog (30 -60 ipm) to see if it can move down the table without faulting. That will tell you if its a servo fighting each other problem as they move along.
You may have to soften the tune if they are fighting.
Are the 'a' (amps) parameters set the same for both drives ?
Larry
Larry-
I installed the repaired drive today and it is working.
I am still having issues that you might be able to help me with.
The other x axis drive is still faulting. I am getting multiple LED error codes. It just depends how much I screw with it and the settings I use. The codes are 5,6,7 flashes.
Here is what is happening--
if I dis engage the bad servo from the rack and have it spinning freely, and only the one side driving the gantry, it moves up and down the table with ease. Gantry sways back and forth, but that is because it is being driven from only 1 side.
At this time, I am watching the dis engaged pinion spin and it is very jumpy.
The servo is connected to a duratrue gearhead, so I removed the servo from the gearhead.
With the servo just spinning by itself, it is still jumpy. I put a mark on the case and aligned it with the keyway. This is at 11 o'clock when you look at it.
when the servo turns counter clockwise it is very smooth and steady until it get to about 7 o'clock. Once it gets to 7'oclock it violently and rapidly spins to the start at 11 o'clock position.
It then oscillates a few times, then continues to the 7 o'clock position where it continues again.
with the power turned off the servo spins freely and evenly. With the power on, it locked in one position, but I can force it to move.
any ideas?
Steve
When it holds, is it holding the same both cw and ccw ?
It could be a problem with the encoder, make sure nothing is loose.
No . It feels stronger in the ccw direction
What is holding strength as a percentage on the weak direction 10%.. 50%, 80% compared to the good direction ?
It might be 20 percent. I can turn CW no problem.
I don't know if you got my PM i sent, but it sounds like a problem with the drive when it only holds one direction.
Send it back and i will check it out.
If its a plasma, then you may want to put some filters on the power wires to the motor. Maybe a ferrite core and RC snubber at the drive end.
Larry
Larry-
It is a flame cutter, not a plasma. I am going to swap the two drives and see if the servo acts screwy, before I send it back. It might be a few days before I make it back to the shop.
Steve
Larry-
I was able to work on the drive for a few minutes today. I swapped the X and A axis. The servo motor was still acting the same.
I swapped everything back, and then removed the cover to the US Digital E-5 encoder. The disk was covered in a whitish grey powder. I took the encoder apart, and wiped the disk with alcohol. It helped, but it is still skipping. I think I have a new encoder I am going to install sometime this weekend.
I am going to look for a sealed encoder, do you have any recommendations on maker or model #
thanks
Steve
Larry-
I actually got about an hour in the shop today. I swapped the encoder. The motor now turns smoothly.
I am now able to run the gantry up and down the table at 100 ipm.
I am getting a 7 flash error on the drive every now and again. It is usually when the servo motor starts to spin.
I am not sure if this is the drive you added the capacitor to or not. I will check later today.
I am making progress though.
Steve
The drive that is faulting is the one that does not have the capacitor. Do I need to solder one on?
Steve
