Wondering if anyone has found a low cost set screw TTS type holder? Ystool is still selling the ER TTS clone chucks on Ebay, but no set screw holders.
Printable View
Novakon (www.novakon.net) sells set-screw holders and ER chucks, and their "Gold Series" have guaranteed maximum runout - 100% factory tested.
Ray L.
Novakon is 16 bucks for set screw holders, 5 cheaper than Tormach and about what Yusing ER20 costs. They appear to be on clearance. 6mm are 10 bucks (and a quarter inch reamer would probably fix the diameter if you need quarter inch). No runout spec I can find, though.
Looks as if set screw holders are on clearance, lots of "no stock" flags.
Thanks Ray, I didn't know that Novakon sold those. Not sure what the deal with the no stock is.
Good idea on the reamer GL. Could also bore some out bigger. I did order ten of the ER20s from Ebay today.
Not closeout, just not always in stock. There's not huge demand, and the make them in batches, so are sometimes out of stock on some items. Not sure they have "Gold" setscrew holders, but if you e-mail them, you can get the "straight poop".
Ray L.
OK, thanks. Not really sure that I would need super accurate set screw holders. I use them for larger size end mills and will use my most accurate ER collet holders for the really small end mills. I did order several of the set screw holders that they had in stock and I will compare the accuracy to my Tormach TTS holders
So I grabbed a couple, and set up in the lathe. Reamed 0.2500. No trouble reaming with HSS chucking reamers. Quarter-inch carbide mills go "pop" after reaming, and the TTS side is 0.7495 according to my mic. Didn't check hardness of the shank. They fit my 1100 just fine. Setscrew is metric, but 3/8 16 size, flat. Runout on the reamed units was <0.0003 with a carbide test bar, in my mill.
Short summary- these seem to be decent, and are around $11.50 apiece with shipping. If you've got drills and reamers, they're about half the price of the Tormach setscrew holders for 5 minutes of work. No cone on the TTS end, no groove for ATC, and probably not enough depth in the 1 3/8 ring to make them ATC compatible (don't know, don't have an ATC). They're identical to the original, non-ATC TTS holders Tormach sold, at least visually.
For comparison, 1 3/8" 4140 HT TGP is 20 bucks a foot, plus shipping - call it 8+ bucks for a piece long enough to make one setscrew holder, plus machining time.
Incidentally- John Saunders did some accuracy checks on setscrew holders. He believes they are both better overall for holding tooling vs ER20, even without a Weldon flat, and runout was negligible. He's published a video on his channel.
I just got the ones I ordered a few days ago. Some of them have the cone on the end and the groove for ATC and some don't. The low cost ER collet holders from Ebay I recently got don't have the cone either. I will probably grind cones on them all on my surface grinder at some point.
You can easily cut the cones and ATC grooves on a lathe using a carbide insert parting tool. It's actually kinda fun - the chips come streaming off glowing bright orange! You should ask if they have them with the cones and grooves already in them. They do for the ER chucks, and probably would be willing to do so for the set-screw holders if there's enough interest to justify making them.
Ray L.
Note: This comment is up to date as of March 2019.
I spoke with Mike Li at IGStool.com ([email protected]) and his current offering for TTS compatible tool holders (ordered directly from him) is:
- ER20 with TTS compatible ATC groove 1.38" long 3/4" shank, $17 USD
- Set Screw endmill holders with TTS compatible ATC groove (1/8, 1/4, 3/8, and 1/2"), $18 USD
- FMB22 Face mill holder with TTS compatible ATC groove (looks like a common size for cheap import facemills, 22mm bore), $19 USD
In addition, the related ebay page offers non-ATC geometry collet chucks in the following sets:
- ER20 1 pc., $17 USD + $13 shipping
- ER20 5 pc., $70 USD + $23 shipping
- ER20 10 pc., $120 USD + $50 shipping
- ER16 10 pc., $120 USD + $50 shipping
- ER16 Floating Tap holder (requires modification to work with TTS) $70 + $16 shipping
- ER32 10 pc., $120 + $60 shipping
- ER32 5 pc., $80 + $36 shipping
- ER25 10 pc., $130 + $60 shipping
I've been using these non-ATC ones for a few years (not sure if I got them from him) and have been happy. I don't have an ATC so it wasn't a big deal. The ones I have have runout between .0005 and .0025. The low runout ones are pretty good, but the high runout ones are only good for roughing.
Mike stated that if any chucks were found to have runout exceeding their stated tolerance (<0.01mm = <.0004") they would replace them with new units from their US stock.
I am going to order a few of the ER20 ATC chucks and make sure I get ones with acceptable runout. I will probably then use these most of the time and use my old ones for less accurate tools.
I looked at the prices and by the time you pay shipping charges they’re almost the same price as buying them hem from Tormach.
Most of mine (I have about 50, both ER20 and ER32) were made by Darkon:
DARKON™ ER20 ATC Precision Chuck - 4GT.com
I've been very happy with the quality. In fact, they are better made than the genuine Tormach ones.
Ray L.
I just checked Little Machine Shop (https://littlemachineshop.com/) and they still have TTS holders at the old Tormach price of $39.95 for ER16/ER20, $44.95 for ER32 and $27.95 for screw holders.
I have found quite bad errors in the cheaper copies in the past - I discuss it in this video.
If you buy them be sure to check the accuracy per geometery as per video. Cliff
https://www.youtube.com/watch?v=AlWTDUvF_ZI
Keen,
Awesome analysis, thank you. I had planned to inspect these thoroughly as I have an agreement with the seller to replace any chuck out of spec. I used to work in a metrology lab, so I appreciate your method. I intend to check the taper in a vee block. I also own a super precision ER20 collet which I plan to run a mandrel test in the vee block on top of the tests you showed. This should give me an understanding of the combined effects of the taper angle and tolerances of the nut.
The reason behind my selection of an import holder is this. My CNC is not a tormach nor will it likely hold the tolerances that a Tormach would. For me (hobbyist), having a wider selection of pre-chucked tools is a better bang for the shop funds than having a smaller number of higher precision tools. Should the day come where I need to run a small production run of parts, I would go for the Tormach chucks without a thought in my mind.
As a note, this particular seller adds his distribution costs to his shipping charges. For 10 chucks I was charged $42 to ship. $35 from China to US and $7 from US to me. This brings the cost per piece to $21. This is still less than half of the Tormach price (before shipping), and cheaper than the Darkon version so I am ok with it. It was either this or have the price already added to the price of the chuck (just a little more surprising this way).
Note, This post contains information on chucks received March 2019.
OK, chucks made it in last week. I have mixed feelings about the quality of the product, but I don't regret buying them. Here is my best attempt at an unbiased review. I will make some comparisons between the Tormach TTS tools I have as well as my previously purchased non-ATC chucks.
Shipping and Packaging: Tools arrived within 3 week days from me placing my order via USPS. They were placed inside a double bagged padded Priority Mail envelopes. Each chuck was wrapped in a plastic bag with rust inhibitor and then inside a telescoping plastic tube that tools usually come in. I was a little concerned about damage due to the soft packaging, but there were no issues.
Appearance: The chucks have a nice general fit and finish. The black oxide is dark and even and the machined surfaces of the chuck body are nice. The shank, collar, and OD near the ATC groove of the tool is ground with a fine finish. My previous import chucks had a rough grind to the collar that hits the nose of the spindle, but these new chucks were as smooth as my Tormach tools. The body, threads, and taper of the tool appear to be hard turned. This made me nervous, but shouldn't immediately disqualify precision since hard turning can be as accurate as grinding if done right. The taper had microscopic machining chatter marks (the kind that looks like a mirror shine until you pull out a magnifying glass) but certainly not anything significant enough to cause issues. The taper is smoother than the ground taper on my other imports, but I don't have a Tormach ER chuck to compare against. The threads are burr free and have no chatter.
The collet nuts have a lower quality black oxide and the information is laser engraved on the face. The threads and taper are again hard turned and look quality. Two nuts had poor surface finish/scoring on the taper (likely from a broken tool during manufacturing) and were set aside to be discarded.
Hardness: I used a fine cut file on the back of the holder, near the taper, and on the nut. The file skated across the surface without really biting but did not feel glass hard. I would loosely guess a low to mid 50's Rockwell C scale. A single nut had 5 hardness test dimples present on the face. I did not receive a chuck which had witness marks from a hardness test.
Taper Runout: Chucks were tested by rotating the shank in a Vee Block with a .0005 dial test indicator mounted magnetically to the block. I would have liked to use a .0001 dial indicator, however I did not have a way to measure the taper with this. An extra vee block was used to weight the shank down into the Vee to prevent error due to uneven pressure during measurement. The face of the collar was firmly pressed against the side of the Vee block during the test. This is necessary to keep the indicator in the same location in the taper, however any error in the collar grind will falsely show up as runout in the taper (due to axial motion of the chuck). Chucks and nuts were serialized. Runout was measured at 3 locations within the taper and an average is reported below:
- Chuck 1: .0003” (.008mm) TIR
- Chuck 2: .0003” (.008mm) TIR
- Chuck 3: .0003” (.008mm) TIR
- Chuck 4: .0002” (.005mm) TIR
- Chuck 5: .0004” (.010mm) TIR
- Chuck 6: .0006” (.015mm) TIR
- Chuck 7: .0008” (.020mm) TIR
- Chuck 8: .0008” (.020mm) TIR
- Chuck 9: .0011” (.028mm) TIR
- Chuck 10: .0012” (.030mm) TIR
Assembled Runout: Chuck assemblies were tested using a Techinks 1/4" Precision (.0002" TIR) ER20 collet and a 1/4" carbide dowel seated to full depth in the collet and measured at 3xD (0.75") from the face of the chuck using a .0001" Dial Indicator. The two nuts which were improperly machined were not tested to prevent damage to the collet. Additionally, chucks 7-10 were not tested due to the excessive taper runout. Each chuck was tested with each nut to find combinations that minimized runout. Understand that at least .0002" (if not more) uncertainty in measurement is introduced by the collet, wear on the collet, and the carbide dowel. Chucks were tightly to roughly equal torques, but I do not use a torque wrench, so some uncertainty is introduced there.
Runout varied from .0003" to .0026" with an average assembled runout of .0013". This leads me to believe that either the threads on the collet chucks, or the nuts have machining errors which cause the taper in the nut to assemble off center of the taper in the chuck. I was able to match nuts to chucks 1-5 which gave the following runouts:
- Assembly 1: .0004"
- Assembly 2: .0003"
- Assembly 3: .0006"
- Assembly 4: .0004"
- Assembly 5: .0009"
Repeatability of these matched chuck assemblies unfortunately is not very good. For example, reassembling Assembly 1 yielded the following:
- Assembly 1 Test 1: .0004"
- Assembly 1 Test 2: .0012"
- Assembly 1 Test 3: .0016"
- Assembly 1 Test 4: .0006"
Customer Service: I contacted the seller of these chuck and stated that I had 5 units which did not meet their stated tolerance of 0.01 mm TIR. I explained my measurement method and the results I got. The seller was concerned that my methods may have introduced error in the measurements which was the source of the excessive TIR, but offered to send me 5 replacement chucks immediately. I have not yet received these in the mail, but I am very happy with this outcome.
Closing thoughts: All in all I am happy with the purchase of these collet chucks since my expectations were set reasonably. I have 5 chucks which I can (with a little trial and error) assemble within .0005" or so TIR. For me, having more TTS tools was more important than having 2-3 very precise chucks since I can create a library of pre-assembled tools that I can add to my CAM software. Since I won't need to take the chucks apart nearly as often to swap tools in and out, I can afford to take the time to assemble them for minimum TIR.
If you want less expensive TTS ER20 chucks ($20/ea vs $45/ea) and are willing to take the time to inspect the product and deal with some higher TIR chucks, then I would recommend this product.
This is likely the difference between a solid nut and a bearing nut . Whats happening is the collet is twisting because of the solid nut , there is a lot of friction . It's not an uncommon occurrence even with high end holders which have a solid nut . This is the main reason why bearing nuts exist .A bearing nut provides much better consistency . The nuts are floating and by right should seat themselves but friction has a funny was of dealing with things . The taper is the precision to be concerned with
A slight bit of lube might help . An easy resolution to the problem is to snug up the collet holder , dial the tool and lightly tap the nut to help it seat properly in position . Tighten then check it again .
The common argument to the resolution is " I won't hammer on precision tooling " , which is ridiculous because it's hardware and it doesn't require a 5lb hammer . We tap vises , parts etc into place .
Reason I mention this is that I've heard the argument too many times , but it's an old trick that works and saves a lot of grief
In your dial tests , did you check to see if the pin is running parallel to the holder shank
That's great advice. I could pick up a few bearing nuts to try them out as well.
Couldn't run the indicator along the tool on the setup I used but I would happily check a few to see. I did take runout measurements at varying lengths from the chuck and found them fairly consistent with the measurements closer to the chucks. There is some angular misalignment of the tool to the chuck, but not much compared to the radial runout. Try to get some real numbers to back up that statement.
I'd recommend trying what I suggested before buying bearing nuts . The inconsistent results are a good indication of binding . A lot of the time it only takes one tap with a hammer to knock everything in place . The whole point of the nut is to force the collet into the taper which is where the precision alignment is . The nut threads are loose and there really isn't much precision to the nut other than the taper . This allows a lot of play for what should be proper alignment of the collet , but the binding is what will throw things out of wack .
I have about 40 of the cheap ebay holders and I can have them run dead-nuts without much problem , and thats with the cheap ebay collets
