mactec54 - Sorry, “mounting plate” was the wrong term on my part...I meant using the base plate from the stepper after disassembly.
Joe - Saw the larger motor in your video....seems like a logical choice.
Todd
Printable View
well, just couldn't help myself.. i battled sleet snow and ice today... and would up with another boss mill... complete with mist unit, flood pump and tank and a good amount of taper 30 tooling...
Ahhh, another project :) Funny how that just happens sometimes.
So,,, one turned into four.... Finally broke down and bought a pallet jack.. used of course.. then had to repair it ..Spent the past 2 weeks making pallets for 3 of the 4 CNC bridgeports. busted my ass moving all my machines around in the shop. Even with the pallet jack its rough pushing these around by yourself ( i was using pipes ) agonized over what machines i could let go and put a bunch of wood working stuff on CL. So, now i have 3 of them where i want them and where i can work on them.. Left them on the pallets so i can easily pull them away from the wall to work on the electronics.. I may tweak them some as well.. possibly angle them a bit.. Now its time to order more parts.. need some circuit breakers, contactors etc to proceed on the controls
DMM 750W AC Servos DMM | AC SERVO DRIVE | AC SERVO MOTOR | ROTARY ENCODER
Ok Gang, its been awhile... have been working on the Rigid Ram for the most part.. have the old electronics stripped out.. the machine cleaned, the oilers replaced and the control cabined blasted and powder coated.. have it re-mounted and now starting to work on the electronics
color matches pretty good ! lol now ill start mounting the electronics !!! Centroid Acorn stay tuned
here is the gear.. waiting on my VFD but i will be mounting the rest while i wait !
