Seems good
Another couple of suggestions, so to aid any editing at the control
- seeing you have not used coolant yet, I would force a M9 ( coolant OFF ) after the M5, won't do anthing if coolant is already OFF, but if you forget to turn ON & edit it in at the control, you'd also have to edit in the OFF codes as well.
- I would restate the last coord system after the G58 X0. Y0.
so that rotary origin is returning to the G54 part origin setting, not the G58 setting
- plus if you do manual moving, it is relative to the part's origin
Code:
N320 G91 G28 Z0.
N330 G90 G58 X0 Y0
N340 G0 G90 G54 A0.
N350 M01
It is called up with the pwcs postblock ( not sure if * is required before it ).
it will need to look like .... pbld, n$, *sgcode, sgabsinc, pwcs, protretinc, e$
or pbld, n$, "G0 G90", pwcs, "A0.", e$
it will depend on how you editted your post.
great ideas there.
i have inserted a *sm09 after the *sm05 to force a coolant off. have tested the post and that outputs as required.
the g54 on the other hand is proving to be a prick.
the only way i can get it in the system so far is by "G54" and not the pwcs that you suggested.
i know that i am editting the correct section of the post cause if i change one of the other g codes on the save line say change the "G90" to "g90" the lower case g that i changed outputs in the post.
i assume the pwcs is the correct way to do it. even is i put a *pwcs it still doen't output the code. maybe there is an issue with the pwcs section of the post that you can see.
pwcs #G54+ coordinate setting at toolchange
if mi1$ > one,
sav_frc_wcs = force_wcs
if sub_level$ > 0, force_wcs = zero
if workofs$ <> prv_workofs$ | (force_wcs & toolchng),
if workofs$ < 6,
g_wcs = workofs$ + 54
*g_wcs
else,
p_wcs = workofs$ - five
"G54.1", *p_wcs
force_wcs = sav_frc_wcs
!workofs$
as for how i have editted the post i have a few of the "g90" type entries and a few *sg90 or *sgcode in there. either way seems to work. should i be doing this a certain way or does it make no differece???
