Originally Posted by
CarveOne
I like how you have integrated the table supports with the side tubes. Even after the wood blocks have been surface planed there may be some changing of the dimensions with time. If that should happen you can replace the blocks with a layer of MDF. I use two layers of MDF and just surface the top spoil board layer. You are in a dry climate most of the year, I think, and may not have the same problems as I do in a humid climate. Coat the blocks with polyurethane or other type paint and it will help.
CarveOne
