Hi All,
My Web Site is back up.
Printable View
Hi All,
Wayne,
Your site seems to been down again.
George
Thank you George!
It is back up again. Evil Hackers keep getting into the Host and pilfering the client web sites. Anybody have a suggestion for a hack proof Web host I can use ? This has happened several times. They also overrode the IP filters that was placed on it.
Wayne
Wayne,
Dunno who you are using currently, but one of the forums I admin has Dreamhost as our hosting service. We've had very good service from them, and they are very attentive to security.
Mark
D.P.
Here is your sample output.
Thank you,
Wayne
i tried using this program and got mostly unusable garbae on the convert. is there anything else i can use?
"unusable garbage" may be because you need to remove the tool movements. If you're trying to convert a 2D file (laser cutter, router, mill..) use the ignore height past .010.. then you'll get only actual cuts, not tool movement. Otherwise, the converter works by the book, and pretty darn good.
the dialog window i get when i run the program only allows me to import the g code file. there is nothing that would allow me to set any restriction on heights.
Thanks Wayne for this small and neat proggy.
Is this possible to eliminate G0 and G1 rapid movements subs?
I clean file manually, which is painful for larger files.
WayneHill, thank you for a very useful program!!!
When I click on My Blog | My Wordpress Blog all I get is wordpress blog.
How do I get to codemangler?
What is happening , I didn't type it this way. Something is mangling
what I type.
My question was: how to connect to www.codemanler.com.
All I ever get is The Blog by wordpress.
Where i can download "G-Code to DXF" now? Link in the first post is broken...
please i need program gcode to dxf
pleaseeeeeeeeeeeeeeeeeeeeeeeee
abd,
See post #15
Wayne
Something tells me the zip file in post#15 isn't the one you were selling. Am I correct? I went looking for your previous website that was constantly getting hosed by perpetrators (sorry to hear that) but couldn't find anything new or of late.
link isnt any good, perhaps too old, can someone fix?
Hello, i dont think so that there is a new link it's to old ; )
