Morbidelli Author 504K RS232 settings
Hi people.
I have 2 machines:
1; Morbidelli Author 504k
Control Tria 7500
2; Morbidelli Author 504
Control Tria 7500
Normally we load the programs via floppies, we want to use the serial port of the controller, but we don't have the manual, I have googling but I have not found the info.
Some could help me with this info? I will build the cable what is the configuration? Someone have the manual for this machines?
Last thing, how to setup the connection?(Parity, Stop Bit, etc, etc.)
Thanks all for your time, hope someone could show me some light, I will apprecited, thanks again for your time!!!
Need help for transfering files through RS232 Author 504
I have Morbidelli author 504 CNC machine I want to use my pc to send files to the CNC machine.
Does anyone know how can I do that?
what dnc software is compatibil with author 504.
I use RS232.
Morbidelli Author 503 (1995)
Hi all.
Is there anyone who can tell me if you can use G code X Y Z generatet from PC then transfered to the CNC by floppy disk?
example would be nice
I ask because right now we program directly on the CNC point to point and we use autocad to get the point to points and then punch them in manualy and some of the programs are very very long so it would be good to have a program where you can import the autocad drawing and generate the X Y Z and just copy it to a floppy disk and load it as a SUB program.
Any ideas is helpful guys.
Best regards
Flemming
problem with Morbidelli Author 455
Hello to everyone, i have a cnc morbidelli , Author 455, i have an error massage: "Plc80:tool out of possition" when the router is working, it's stops and i have this error. some times the analoge output from plc to inverter(must be 10volts) is 3.48volts and the machine stops. I check the limit swich, and is ok.
I don't know what else i have to check. The orizontal router is working.
thank you very much.
