Hi all,
I've just configured EMC2 for use with my homebrew engraver/mill. I'm really pleased with the way it went, pretty much hitch free (once I'd read the manual :)). Much nicer than the TurboCNC I'd been using previously.
The machine has only a small Z movement. I've configured the axis to home to a switch at +15mm.
Most of the time, pressing 'home', winds the Z axis up to the switch then up/down before reseting the machine position display to 15.000 (exactly as expected). However after I've run an air cut, zeroed the axes with g00 x0 y0 z0, then press home all (or Z only) it'll home up to the switch jiggle (at about 15mm) then reset the display to 14.300.
I don't think the Z axis is losing steps (and in any case the home should reset to 15.000 every time shouldn't it?)
Any ideas?
Oh and while have your attention; How do you get EMC to start full screen? (I'm a linux newbie)
http://www.cnczone.com/forums/attach...5&d=1217953810
