Re: Panelmate Touch Screen
I asume you have that touch panel installed on a windows machine.
When you uninstall the touch screeen, windows keeps the drivers on the machine. It only removes the installed touch screen.
If you reboot windows and plugin your touch screen, it will be recognized and Windows will install the drivers. If you Google, you will find a lot of answers how to uninstall a driver. I do this by selecting the installed device in windows hardware and remove the device. Windows will than ask to remove the drivers as well.
Next step is to disconnect the device, install the right drivers and than connect the device.
This explains how it is done, It works in all windows versions.
https://www.elevenforum.com/t/how-do...program.18232/
