Quote:
#include "KMotionDef.h"
// Press Brake Run Version 4.0.3
// ADDED RAPID
//120mm/s Approach
//10mm/s Pressing
//100mm/s Return
enum { HOME, RETURN1, RETURN2, IDLE, DOWN, DOWNFAST, UP, DELAY, BOTTOM, TOP, RETURN}; // states
#define CLOSE 136
#define OPEN 137
#define RAPID 140
#define TOP 139
#define BOTTOM 138
#define SLAVE 1
int state = IDLE;
int slow = 2000; //2000 for pressing 40000 High Speed
int medium = 20000;
int fast = 20000;
double DelayTime;
int offset; //OFFSET
int Y3 = 144;
int Y5 = 145;
int A0; //PRESSURE
float a10; //Dwell calculation
int a12; //Dwell calculation
int dwell; // Bend Delay
int cnt1 = 0; //Pressure OFF after count
int automode = 0; //Auto Mode
int position = 0; //Destination Position for leveling
main()
for (;;) //forever loop
switch (state)
//WAIT FOR COMMAND TO MOVE
case IDLE:
if (!ReadBit(BOTTOM) && ReadBit(CLOSE)){ SET_OFFSET(); state = DOWNFAST; } //SET_OFFSET();
if (!ReadBit(TOP) && ReadBit(OPEN)){ ZERODEST(); state = UP; }
cnt1++;
Delay_sec(0.01);
if (cnt1 >= 2){ V_IDLE(); } //PUT PRESS VALVES INTO IDLE MODE AFTER 2 10THS OF A SECOND.
break;
//GOING DOWN FAST
case DOWNFAST:
if (ReadBit(RAPID)){ V_APPROACH(); Jog(0, fast); Jog(1, fast); state = BOTTOM; } //FAST CLOSE //RAPID REVERSED FOR EXTERNAL SWITCH ACTIVATION.
if (ReadBit(BOTTOM)){ Jog(0, 0); Jog(1, 0); SET_DWELL(); state = DELAY; }
break;
//GOING DOWN
case DOWN:
if (!ReadBit(BOTTOM) && !ReadBit(RAPID)){ V_PRESSING(); Jog(0, slow); Jog(1, slow); state = BOTTOM; } //CHANGE TO SLOW CLOSE
break;
//WAIT FOR LIMIT OR RELEASE OF (FOOT PEDDLE OR DOWN BUTTON).
case BOTTOM:
if (!ReadBit(CLOSE)){ Jog(0, 0); Jog(1, 0); cnt1 = 0; state = IDLE; }
if (ReadBit(BOTTOM)){ automode = 1; Jog(0, 0); Jog(1, 0); SET_DWELL(); state = DELAY; } //Put into auto mode.
break;
//DWELL AT BOTTOM
case DELAY:
if (Time_sec() > DelayTime){ state = UP; }
break;
//GOING UP
case UP:
if (!ReadBit(TOP)){ V_DECOMPRESSION(); Jog(0, -slow); Jog(1, -slow); state = RETURN; } //SLOW OPEN
if (ReadBit(TOP)){ Jog(0, 0); Jog(1, 0); ZERODEST(); cnt1 = 0; state = IDLE; }
break;
//RETURN AT MEDIUM SPEED
case RETURN:
if (!automode && !ReadBit(TOP)){ V_RETURN(); ZERODEST(); Jog(0, -medium); Jog(1, -medium); state = TOP; } //MEDIUM OPEN
if (automode && !ReadBit(TOP)){ V_RETURN(); ZERODEST(); Jog(0, -medium); Jog(1, -medium); state = HOME; } //AUTO GO TO TOP LIMIT THEN LEVEL
break;
//WAIT FOR LIMIT OR (RELEASE OF UP BOTTON IF NOT IN AUTO MODE).
case TOP:
if (!ReadBit(OPEN)){ Jog(0, 0); Jog(1, 0); ZERODEST(); cnt1 = 0; state = IDLE; } //STOP AND PUT BAKE INTO IDLE
break;
case HOME:
if (automode && ReadBit(TOP)){ V_IDLE(); Jog(0, 0); Jog(1, 0); ZERODEST(); automode = 0; }
//MOVE DOWN AND EVEN
if (!automode && ReadBit(TOP)){
int pos1 = ch0->Position;
int pos2 = ch1->Position;
position = pos2;
Delay_sec(0.1);
if (pos1 < pos2){ V_PRESSING(); Jog(0, slow); state = RETURN1; }
if (pos1 > pos2){ V_RETURN(); Jog(0, -slow); state = RETURN2; }
break;
case RETURN1:
if (ch0->Position >= position){V_IDLE(); Jog(0, 0); Jog(1, 0); ZERODEST(); cnt1 = 0; state = IDLE;}
break;
case RETURN2:
break;
//----------------------------------- VALVE CONTROL ------------------------------------------------------
V_IDLE()
//SET SPEED TO ZERO
int max = 0; ch0->MaxOutput = max; ch1->MaxOutput = max;
ClearBit(Y3);
ClearBit(Y5);
DAC(2,0); //Pressure Setting Zero
V_APPROACH()
//SET SPEED TO NORM
int max = 600; ch0->MaxOutput = max; ch1->MaxOutput = max;
SetBit(Y3);
SetBit(Y5);
A0 = ADC(0) * 2.12; //0 - 945 Reading Pressure Setting
DAC(2, -A0); //SET PRESSURE
V_PRESSING()
//SET SPEED TO MAX
int max = 2000; ch0->MaxOutput = max; ch1->MaxOutput = max;
ClearBit(Y3); //Experiment
SetBit(Y5);
V_DECOMPRESSION()
//SET SPEED TO ZERO THEN TO MINIMAL
int max = 0; ch0->MaxOutput = max; ch1->MaxOutput = max; //Instant Stop
ClearBit(Y3);
ClearBit(Y5);
Delay_sec(1.0);
int max = 100; ch0->MaxOutput = max; ch1->MaxOutput = max;
V_RETURN()
//REGULATE UP SPEED
int max = 300; ch0->MaxOutput = max; ch1->MaxOutput = max;
ClearBit(Y3);
ClearBit(Y5);
//------------------------------ SET DWELL -----------------------------------------------------------------
SET_DWELL()
a10 = ADC(1) / 189;
if (a10 > 189)
if (a10 > 0 && a10 <= 1){dwell = 1;}
if (a10 > 1 && a10 <= 2){dwell = 2;}
if (a10 > 2 && a10 <= 3){dwell = 3;}
if (a10 > 3 && a10 <= 4){dwell = 4;}
if (a10 > 4 && a10 <= 5){dwell = 5;}
if (a10 < 189){ dwell = 1; }
if (a10 < 0){ dwell = 1; }
DelayTime = Time_sec() + dwell; state = DELAY;
//------------------------------ SET OFFSET -----------------------------------------------------------------
SET_OFFSET()
int a3 = ADC(2);
int a5 = convert_value(a3);
ch0->MaxOutput = 600;
ch1->MaxOutput = a5;
//printf("Y1 MaxOutput = %d\n",a5);
state = DOWN;
convert_value(int a3){
// Calculate the scaling factor (avoid floating-point math).
int scale_factor = (620 - 610) * 1000 / (945 - 4);
// Apply the scaling factor to a3 and offset by 610 to get the new value.
int new_value = a3 * scale_factor / 1000 + 610;
return new_value; }
//---------------------------------------- ZERO DEST AND ALL -------------------------------------------------------------
ZERODEST()
ch0->Dest = 0; ch1->Dest = 0; Delay_sec(0.1);
ZERONOW()
Zero(0); Zero(1); Delay_sec(0.1);
main()
ch0->InputMode=ENCODER_MODE;
ch0->OutputMode=DAC_SERVO_MODE;
ch0->Vel=1000;
ch0->Accel=400000;
ch0->Jerk=4e+06;
ch0->P=30;
ch0->I=0;
ch0->D=60;
ch0->FFAccel=0.025;
ch0->FFVel=1.2;
ch0->MaxI=1000;
ch0->MaxErr=2e+06;
ch0->MaxOutput=600;
ch0->DeadBandGain=1;
ch0->DeadBandRange=0;
ch0->InputChan0=0;
ch0->InputChan1=0;
ch0->OutputChan0=0;
ch0->OutputChan1=0;
ch0->MasterAxis=-1;
ch0->LimitSwitchOptions=0x100;
ch0->LimitSwitchNegBit=0;
ch0->LimitSwitchPosBit=0;
ch0->SoftLimitPos=1e+09;
ch0->SoftLimitNeg=-1e+09;
ch0->InputGain0=1;
ch0->InputGain1=1;
ch0->InputOffset0=0;
ch0->InputOffset1=0;
ch0->OutputGain=-1;
ch0->OutputOffset=0;
ch0->SlaveGain=1;
ch0->BacklashMode=BACKLASH_OFF;
ch0->BacklashAmount=0;
ch0->BacklashRate=0;
ch0->invDistPerCycle=1;
ch0->Lead=0;
ch0->MaxFollowingError=1000000000;
ch0->StepperAmplitude=20;
ch0->iir[0].B0=1;
ch0->iir[0].B1=0;
ch0->iir[0].B2=0;
ch0->iir[0].A1=0;
ch0->iir[0].A2=0;
ch0->iir[1].B0=1;
ch0->iir[1].B1=0;
ch0->iir[1].B2=0;
ch0->iir[1].A1=0;
ch0->iir[1].A2=0;
ch0->iir[2].B0=1;
ch0->iir[2].B1=0;
ch0->iir[2].B2=0;
ch0->iir[2].A1=0;
ch0->iir[2].A2=0;
ch1->InputMode=ENCODER_MODE;
ch1->OutputMode=DAC_SERVO_MODE;
ch1->Vel=1000;
ch1->Accel=400000;
ch1->Jerk=4e+06;
ch1->P=30;
ch1->I=0;
ch1->D=60;
ch1->FFAccel=0.025;
ch1->FFVel=1.2;
ch1->MaxI=1000;
ch1->MaxErr=2e+06;
ch1->MaxOutput=620;
ch1->DeadBandGain=1;
ch1->DeadBandRange=0;
ch1->InputChan0=1;
ch1->InputChan1=0;
ch1->OutputChan0=1;
ch1->OutputChan1=0;
ch1->MasterAxis=-1;
ch1->LimitSwitchOptions=0x100;
ch1->LimitSwitchNegBit=0;
ch1->LimitSwitchPosBit=0;
ch1->SoftLimitPos=1e+09;
ch1->SoftLimitNeg=-1e+09;
ch1->InputGain0=1;
ch1->InputGain1=1;
ch1->InputOffset0=0;
ch1->InputOffset1=0;
ch1->OutputGain=-1;
ch1->OutputOffset=0;
ch1->SlaveGain=1;
ch1->BacklashMode=BACKLASH_OFF;
ch1->BacklashAmount=0;
ch1->BacklashRate=0;
ch1->invDistPerCycle=1;
ch1->Lead=0;
ch1->MaxFollowingError=1000000000;
ch1->StepperAmplitude=20;
ch1->iir[0].B0=1;
ch1->iir[0].B1=0;
ch1->iir[0].B2=0;
ch1->iir[0].A1=0;
ch1->iir[0].A2=0;
ch1->iir[1].B0=1;
ch1->iir[1].B1=0;
ch1->iir[1].B2=0;
ch1->iir[1].A1=0;
ch1->iir[1].A2=0;
ch1->iir[2].B0=1;
ch1->iir[2].B1=0;
ch1->iir[2].B2=0;
ch1->iir[2].A1=0;
ch1->iir[2].A2=0;
EnableAxis(0);
EnableAxis(1);
DefineCoordSystem(0,1,-1,-1);
