Hi!
I have BIGLIA 501 with FANUC-18T. I can not make SRAM dump via PCMCI card due to "Pariry Error". I want to download parameters via RS232 interface.
What programm to use? Are there any FANUC native program to do it?
Printable View
Hi!
there are many software to download but i use from long time CIMCO EDIT for transmission
If the SRAM backup in BOOT mode results in a parity error, you will likely also get that when downloading the programs. Try deleting the offending program and then do the SRAM backup.
...try changing "Bit Parada" to 1 or 0
DJ
Could you solve the problem?
I’m using COMMUNICATION SOFTWARE FOR FANUC CNC with the same FANUC CNC.
It is specially designed for FANUC CNC though it can be used also with other CNC.
It has several built-in help menus that show you how to use it with your CNC.
You can download it from “The SOFTPEDIA· web page.
