8 Attachment(s)
Build Log: Vevor 7x14 Lathe, closed loop steppers, no design yet...
1 Attachment(s)
Re: Build Log: Vevor 7x14 Lathe, closed loop steppers, no design yet...
3 Attachment(s)
1 Attachment(s)
1 Attachment(s)
1 Attachment(s)
4 Attachment(s)
2 Attachment(s)
Got everything wired and connected and had first movement last night (sorry, no video). Had to revert to the SmoothStepper and Mach3 since UCCNC does support Lathes (yet?).
https://www.cnczone.com/forums/attac...d=495478&stc=1
https://www.cnczone.com/forums/attac...d=495480&stc=1
Only a couple gotcha's to get it running. The E-Stop I had was Blue-White-Green wires. I figured green would be ground and Blue-White were signal, but instead Blue-Green is NO, and White-Green is NC, so had to rewire that. Then I could not get motion and it took me a while to discover I needed to run 5V to the ENABLE pin on the C10 power pin to enable Outputs on that card (lights up a green LED when they are enabled). Also had to flip the switch on the Stepper cards from 24V to 5V signal. Now have motion on both axes, and need to work on real-speccing the "steps per" to real world units. Bought Ease-e Turn, but haven't received it yet. Hope it's better than sliced bread because it is a PITA to get ahold of!!!
