We have COLCHESTER TORNADO 80 with GE-FANUC 21-t
At each attempt to rotate the spindle, it emits an alarm 1007 which monitors the hardware failure. Is there a remedy procedure? Thank you
Printable View
Colcester has a separate pcb for monitoring the spindle speed and there is a procedure for that pcb reset or set up
here you will find a lot of info
https://www.cnczone.com/forums/colch...ornado-lathes/
good morning, thanks for the replies.
The manufacturer told me to check the connection between the spindle amplifier and the k9 relay.
I attach a working diagram.
I try to check the relay after this the drive board. Thank you
Hello,
Did you managed to solve problem? If so, what was solution?
Best regards
