426 CB 1996 Bridgeport VMC1000-30 Backup
Control LE426 CB
Hardware tag
Id Nr 312 002 29
S. Nr. 6766-336 A
Software
280 472 15
426 630 V04
280 641 -16
I am in dire need of a back up for this machine. We have two but one is missing two files and the other is missing the lst file. I'm certain that one is correct but without a way to read the bkp file I'm dead in the water. Any help would be appreciated.
Is there any way to create an lst file?
Any archive software other than TNCRemo to read a back up file?
Thank you
1 Attachment(s)
Re: 426 CB 1996 Bridgeport VMC1000-30 Backup
Problem solved. You can reverse engineer an .lst file. Open the bck file, save as something other than your bck file. If you mess the bck file up you are toast. scroll to the end of the copy of your file and parse out all of the file names, follow the format in the lst file I have uploaded here and you should be able to access the bck file with TNCRemo.
Consider this thread closed.
1 Attachment(s)
Quote:
Originally Posted by
KevinV_MEI
...need a day Job? ;)
