2 Attachment(s)
Help needed with Esprit 4 axis Wrap contouring
Hello Guys,
I am using Esprit 2019. I am trying to machine a circular groove on this part using the 4 axis on an Okuma mill. I created a chain on the circumference of the part groove. Then I tried using Wrap contouring on Esprit but when i try to create the tool path I get and error message that says "Wrap operation requires wrap axes. Axes is not specified in Machine Setup". I have no idea how to set up the wrap axes. Any help will be really appreciated. Here are a couple of pics of what I am trying to do. Thanks
1 Attachment(s)
Re: Help needed with Esprit 4 axis Wrap contouring
https://www.cnczone.com/forums/attac...d=447062&stc=1
In your machine setup you need to specify that you have a 4th axis. This is from our setup file for a Doosan DNM 6700 with a 4th.
