Starting script needed for home made cnc machine
Hi folks,
I've just setup endstops of X and Y. For my Z I use a touch plate. I want to Home Z using the touch-plate (3.9mm thick) first, then I want it to home X Y before starting the job.
One thing needs to be noted is that my Y homes 142mm past the start of my work area. So I can set an offset on my Y with something like M206 Y-142??? I think.
This is what I have now but I'm very unsure if this will work as I want it to.
;Project <project>
;Created by Estlcam version <version> build <build>
;Machining time about <time> hours
G28 X Y
G1 Y150 F600
M0 INSTALL TOUCH-PLATE
G28 Z (Home Z to touchplate)
G1 Z10 F120
M17 (Enable Steppers)
M0 REMOVE TOUCH-PLATE
G1 Z-3.9 F120
G92 X0 Y0 Z0
G1 Z4 F120
G28 X Y
G90
Thanks in advance,
John
Re: Starting script needed for home made cnc machine
Quote:
Originally Posted by
solly747
Hi folks,
;Project <project>
G28 X Y
G1 Y150 F600
G1 Z10 F120
G1 Z-3.9 F120
G92 X0 Y0 Z0
G1 Z4 F120
G28 X Y
G90
Thanks in advance,
John
Z is never homed to a touch -plate machine Home is Z axes up to it's max travel or where ever you want it to stop by activating the Home/ limit switch
Z axes offset and Touch-Plate is used for setting Tool length offset G43 Etc Tool offsets G43
Work Offsets us G54 Etc
G28 try G53 or just G0
G92 X0 Y0 Z0 never do a Z axes move on the same line as a X and Y axes move Z axes move is always done before a X Y move
1 Attachment(s)
This is how Z axes Tool offset works
Thanks for all this.
Are you able to change what I have to what you recommend as a whole script? G53 is not supported by Marlin (sorry I should've said that's what I was using).
Still trying to get my head around it all.
Thanks again for the reply
solly747
No I can't help you with your control, you are best to try where the Marlin software is used there may be some users on here, but in general that is what is happening when people get into a system with very little support
mactec54
This thread most likely has a better system than what you are working with https://www.cnczone.com/forums/uncat...cam-forum.html
mactec54
Thanks mate
Marlin is great for 3d printers, but not what you want on a CNC. Your way better off going with GRBL or Linux CNC or one of the other open source packages for CNC.
