Can’t get the right surface
Designing an intake runner which changes shapes from oval to circle. I have the dimensions in and have done every option on bobcad v29 and can’t seem to get it right. I can connect lines between the two dimensions creating the runner wall, but it ignores the lines I draw. I’ve done cross section without those lines and results are always the same. When you look down the throat of the design the port is shrouded by the program’s extrapolation every time.
Re: Can’t get the right surface
use ruled surface
draw your circle at one level in Z
draw your ellipse at the other level of Z
break divide by 2
use ruled surface on 1/2 of the circle and half of ellipse
mirror image,,then stitch
the help menu within bob covers it
2 Attachment(s)
Quote:
Originally Posted by
boosted67
Cross Section is what you want. It will allow you to add defining sections for your throat, as opposed to just 2 entity skin...
The issue with what you show, will be, you want your entities to have "EQUAL" segmentation. (You'll want to break/divide your circle to match the little throated piece.
Here are a couple examples. The first zeroed one, is just a default circle and elipse. So just a straight cross section, produces good results.
The second 2, I created you lower throat, that has "6 segments" in it... I divided the arc to 6 then, and got these skins.... (bbcd file attached)
The last thing is when doing these skinning functions, be sure to work with the shift click, instead of just windows select. Do your work so the chain start/end can be in the same place on both entities.
Attachment 418810
If you need more direction, maybe someone else can jump in to show this. I am ill and cant play at a high level right now....
Something was wrong w that particular file. It stopped even highlighting lines. Went back to my base file, broke top in 12 segments and lower into 6 and it cross sectioned no problem.
I’ve been this far before believe it or not lol. I’m just trying to get better at the software. I offset .250 and .187 top to bottom for runner thickness and cap. Now to figure out how to radius the inside at the top. Yeahhhhh. Lol
And bobcad crashes and closes again. Jfc
Regular saves with version numbers on the end of your file help when something goes wrong and you need to roll back to a version that's not broken.
A fast PC with a good graphics card and lots of RAM makes a difference.
2 Attachment(s)
boosted67
BobCAD won`t fillet the solid in this instance, (it is quite normal for it to crash trying to do this operation:(,) what you need to do is go to the "Utilities" tab and use the "Stitching > Unstitch Solid to Surfaces" then you can use the Fillet under the "Surfaces" tab, you can select one slope and the corresponding vertical, set a value for the radius and then it will radius, a bit labour intensive/PITA and when you have done the rads go back to the "Utilities > Stitching >Stich Surfaces to Solid" and you should be back to having a solid with rads between your circle and your oval.
See attached example, might be of some help to you :D :D
Regards
Rob
2 Attachment(s)
I have done stuff in the past using the Skin function and seems to work well
Seems to break into segment automatically
RAF
1 Attachment(s)
What we really need is a "Loft" option that can be found in several other softwares, it would be nice if BobCAD could look at including this in the next version (V32?).
I have attached a short video that shows how very simple, easy and time saving this option can be for lots of designs, it may not be suitable for all but I think a lot of people would make good use of it, anyway on to the video with the rubbish comentary, I only just installed this video capture software today so this is a first attempt at a video, please be kind :D :D :D
It is in .mp4 format that should open and play in Windows Media player that is in most PCs by default :D
Hope it is of some use, if anyone wants me to have a go at creating something similar and don`t already have access to software that will do this then just supply a .DXF file with the shapes and I will endeavour to come up with something for you :D
Regards
Rob
Hi Burr
Yep, I fully agree with you re the "Cross Section" in effect being a version of "Loft", it does work and is very accurate in that as you rightly point out working with lines/arcs is good, more labour intensive but as in my earlier post shows the shape is very accurate in the other software using their "Loft" the user is pretty much at the mercy of the software regarding the actual shape of radii which isn`t such a great thing, but it is much faster and easier so if accuracy isn`t priority then OK, I have found that a little practice with the shapes re number of and heights then it is possible to get pretty close to an accurate required shape, but, nothing is for nothing that also requires some extra labour, again !!
The video is pretty rubbish, particularly the commentary, but it may be of interest to some, never make it as a News Reader that`s for sure, I`ll just stick with the machines, they don`t care what I say or how I say it :D :D :D
Regards
Rob
The Engine Guy
Hi Burr
Regards
Rob
lol. Talks to the machines at night!!! "Hello Darlin.... Make some sweet chips tomorrow, and I'll oil you!!!!"
I want to hear your crusty old voice, so I have a better idea of who I chat with!!!!
Definitely something w that particular file. Computer is slow to highlight or do anything. Open up anything else and it’s fine. So I redrew it in a couple minutes no problem now that I know how to do it. Thanks a ton. May need more soon. Solid fillet isn’t radiusing the inside of the runner at the top. Try a few things here.
https://i.postimg.cc/sXYpkcng/7-E7-F...0088-F2-B6.jpg
https://i.postimg.cc/mgnNChzB/BC8-C9...-B9139-BBB.jpg
Burr,in this particular case,why is "Rule" not a good choice ?
Say I break both entities in 12 0r 24 places,,it seems alright,,maybe an illusion ?
Sure is fast with chain select
Getting the same garbage results. When you turn to a solid you can see how terrible it really is. You can start the chain in similar location, break the top ellipse into 360 if you want, nothing changes
https://i.ibb.co/TgMsT74/80-D62140-3...8-C66-BEB2.jpg
