2 Attachment(s)
CNC lathe for Swiss Type-Bernardo on CNC micro machining 0,2mm turning
Yo
It's time to boast about the first details so it's what :)
https://www.cnczone.com/forums/attac...d=408552&stc=1
Brernardo manual lathe has been converted to CNC.
The use of the machine is modeling mainly very small details - as for me, you can talk about micro-machined holes, eg 0.3 mm or external diameter below 0.2mm - here more modelers could say something, whether it's a lot or not enough :)
You have a unique opportunity to go with me through all stages of construction :)
https://www.youtube.com/playlist?lis...gwQdds-t_VniqB
At the beginning, we will look at the actual quality of the lathe sold as "for the most demanding mechanics"
https://youtu.be/kkU-Fnx0NmI?list=PLfHK ... ds-t_VniqB
then we are dealing with a typical modification but for example I did think that an interesting experiment - how much strength does the stepper motor have (4.2Nm)
https://youtu.be/kmU9D0ILAgY?list=PLfHK ... ds-t_VniqB
Now I will show you a bit bigger and simpler details which was quite troublesome anyway (the quality is not yet staggering but something is coming out.)
https://youtu.be/wByGvE-jvbY?list=PLfHK ... ds-t_VniqB
https://youtu.be/z1DXQlb74Ug?list=PLfHK ... ds-t_VniqB
https://www.cnczone.com/forums/attac...d=408554&stc=1
soon I will show you the smallest details and also show how I solved the coolant system but the next episode will be dedicated to the REPATE function, how to make a program to repeat itself and how to use zero shift in LinuxCNC - in the meantime, I invite you to watch episodes of the whole series :)
Ps. thank you to all forum members for help during the creation - your advice was very helpful :)
I do not speak English, I am using a Google translator but I will answer questions if possible
