Might be missing something in the documentation but my control is currently reporting everything in mm and I'd like to switch over. This is consistent between reboots not something I did. must be a parameter.
Printable View
There is a parameter. If I recall, its under param>level>proto3>3>power or similar. Something like startup units. Mine was inches, but I work in mm.
Be very careful in there, lots of setting that can make a mess of your machine. Dont change a setting unless you know what it's for.
Sent from my SM-G955U using Tapatalk
Save your parameters before you make changes!
Hi Yugami, Yes the power parameter Boot to English or Metric. set to English. you can also do a G20 in MDI but that is not permanent like the power parameter.
sportybob
Here is the ONLY silly question I can get. It is 5 OClock on a Friday and the work is done. Hey Bob, would you like a barley pop. Now that's SILLY. ;-)
sportybob
