Tube coping for cnc plasma
http://metalgeek.com/static/cope.pcgi
This is something I have almost forgotten about, it is a simple program that aids in coping and notching tubing. You enter the tube size that is to be cut, the angle of cope, and the size of tube to be fitted to, and it then draws the cope out as a line that can be printed out, wrapped around the tubing, and then cut.
The really great part, and the reason I put this in the cnc plasma section is that there is a built-in Gcode converter.
I know, I know. It isn't a cnc plasma machine. But, for those that use one, it is a great time saver.
Hope that some of you can use it.
