Hello all,
New guy here with a need for help with surfcam. Can not find an answer after searching through lots of forum posts and all.
I am trying to program a part in surfcam for a 3 axis mill and having trouble with the stock set up.
I create a circle at the depth that material is left from the lathe work and am having trouble with an error that says tool 1 is skipped, because nothing to cut.
If I change the diameter of the circle a little bit smaller maybe 1/4 inch it works fine... but that wont work right when trying to cut it on the mill.
Thanks in advance!
AB
