6 Attachment(s)
Selling my Tormach 770 and everything else too (Chicago)
Tormach - PCNC 770 Series 3
Less than a year ago I decided I wanted to get into machining. I bought a brand new 770 and lots of accessories including the power draw bar. Unfortunately I lost interest very quickly and I am now looking to sell the machine and everything with it.
It’s in essentially brand new condition, I have probably run the spindle for less than 20 hours total.
Hopefully it will find a home with someone who will make good use of it.
It can’t be shipped, so you will need to pick it up. I’m in Chicago and live in a loft apartment right next to the freight elevator. This is extremely heavy, you will need to bring a dolly and some strong friends to help you.
Here is the list of everything I have, with the part numbers. I’m selling everything together.
- 32084 - PCNC 770 Series 3
- 31302 - Manual Oiler
- 33337 - G Wizard Machinist Calculator for Tormach
- 31748 - PCNC 770 Owner's Kit
- 30151 - 30mm Wrench for TTS-ER20 Nut
- 32799 - 5" Parallel Set
- 31789 - 2pc Vise Alignment Keys with Screws for 5" CNC Vise
- 31759 - 5" CNC Vise
- 31386 - Machine Oil
- 35450 - 17" Touch Screen LCD Monitor
- 35286 - PathPilot™ Controller
- 32700 - Pro Ring Light with SuperBright LEDs
- 35537 - 6061-T6 Aluminum: 5/8" x 1-1/2" x 6" (20)
- 31947 - Basic 3 Piece Indicator Set
- 30616 - Jog Shuttle
- 31334 - Chip Guard for PCNC 770
- 30286 - Machine Arm
- 30302 - TTS Tool Tray
- 31991 - Pneumatic Hose Kit for Power Draw Bar/ATC/Fogbuster
- 31728 - Power Drawbar Foot Pedal Kit
- 32436 - PCNC 770 Power Drawbar
- 31761 - 8" Digital Height Gauge
- 31713 - Small Granite Surface Plate with Integrated Tool Hole
- 35356 - TTS-R8 Adaptor Collet
- 34086 - ER20/ER16 Deluxe TTS Wrench Set
- 31709-2 - Carbide Inserts for Aluminum, Plastic, Non-ferrous & Cast Iron
- 2 x 32309 - Passive Probe w/ 10mm TTS Mount
- 32021 - TTS-ER20 Tension/Compression Tapping Head
- Trico MD-2100 Cooler/Mister/Lubricator
- Air lubricator and drier
- Air tool oil
- Trico lubricant
- Lots of aluminium in various sizes (see photos)
- A shop vac
- An air compressor inside a very heavy sound deadening box (it’s very, very quiet - because I live in an apartment building)
- Lots of 31829 - TTS-ER20 tool holders and lots of collets
- Over 40 carbide tools, 90% of them have never been used - see the photos
Everything combined cost me over $15k. If you can come and pick everything up, then I would happily take $10k.
You can see lots more images here : https://dl.dropboxusercontent.com/u/...770_images.zip
http://www.cnczone.com/forums/attach...d=315044&stc=1
I also created a Craiglist post here: Tormach PCNC 770 3 Series CNC machine (and lots of accessories)Thanks! Hopefully this finds a great home!
Re: Selling my Tormach 770 and everything else too (Chicago)
Sounds like a good deal, good luck!
Also, thanks for making the title of this thread actually represent what the thread is about. So often the titles are something like "Have a Q" or "Is this supposed to happen?"...
Hy, I'm interested in. I live in Granby, Quebec Canada. Is the milling is sold? Thanks
Granby! I have been there when the temperature hovered a few degrees above absolute zero.
Home of Line' CNC Machines, one of the best Gantry Mills built.
We have about 10 of them. Longest travels in the 60' range.
Good luck with the Tormach.
Dang, sorry to see you go. 10K is a smokin' hot deal on that machine with all the accessories.
I have close to 21K in my PCNC 1100 and I don't have the ATC.
I tried contacting you by every means possible when I came to Chicago this past week...please PM me.
