Re: Y-axis faults are back
Hi Matt,
I assume you have two brush motors slaved together for your Y axis?
I assume Y is the heavy axis?
Can you do moves using the Step Response Screen and ever capture a fault? If so please post the data.
What are the normal current levels?
I'm not sure splitting across SnapAmp sides would make a difference. But to do that you would keep the Gcode Coordinate System the same and change which full bridge output is used by the KFLOP Axis channels (OutputChan0= 8, 9, 10, 11).
The peak current shut down needs to be very fast to prevent current from rising to high in the event of a short. It wouldn't be a good idea to slow it down.
Did something change? Could it be something like a cable in the rolling loop going bad?
Grounding is very complex. Are the motor supplies isolated from Earth GND? Do you have any ground loops?
Regards
Tom - Responses below in bold text - new questions follow:
I assume you have two brush motors slaved together for your Y axis? Yes
I assume Y is the heavy axis? Yes - moves X w/ Z-spindle
Can you do moves using the Step Response Screen and ever capture a fault? If so please post the data. Have not tried - will do so and post results
What are the normal current levels? How to I determine this?
I'm not sure splitting across SnapAmp sides would make a difference. But to do that you would keep the Gcode Coordinate System the same and change which full bridge output is used by the KFLOP Axis channels (OutputChan0= 8, 9, 10, 11). OK
The peak current shut down needs to be very fast to prevent current from rising to high in the event of a short. It wouldn't be a good idea to slow it down. Not sure I entirely agree, all problems I've had so far have been user / g-code issues - current limit never came into play even in those events. I still wouldn't want to rule this option out.
Did something change? Could it be something like a cable in the rolling loop going bad? No, nothing changed - other than replacing a spindle - don't see how that would affect the Y-axis (see above). Cables for the Y-axis motors are fixed - not in cable chains.
Grounding is very complex. Are the motor supplies isolated from Earth GND? Do you have any ground loops? Yes, I understand grounding/shielding/loops are quite complex and have had to deal with them many times over my engineering career. That said, I have not looked at this in a long time. So, I don't remember how things are setup. I will look to see how the grounds are connected and see what is connected to Earth.
Would / will I get better error messaging running under KMotionCNC? What would be needed to move from Mach3 to KMotionCNC to test this out some of these ideas?
One question you didn't answer:
Looking back through the init code there are only 2 current limit code lines
WriteSnapAmp(SNAP0+SNAP_PEAK_CUR_LIMIT0,15);
WriteSnapAmp(SNAP0+SNAP_PEAK_CUR_LIMIT1,15);
Guessing this is for A / B vs motor outputs 0-3 / 4-7?
Will you please explain how these 2 code lines work on current limiting the 8 outputs?
Matt
Hi Matt,
Use the Step Response Screen. Plot Current. Plot Output.
R24/C48 6.98K/ 47pf form a low pass filter with RC = 0.3us for filtering the peak current measurement on the A Side. R23/C49 do the same for the B side. I suppose the capacitor could be increased to slow the response to noise glitches. We don't recommend this.
A Spindle is typically a major source of noise that can be picked up on Motor wiring, Supply wiring, Grounds, Encoder Signals, etc...
There wouldn't necessarily be any better messaging under KMotionCNC. You might run KMotion.exe while running under Mach3 or KMotionCNC and observe the Console and Status Screens after a fault. The best approach would be to create a User Program to continuously record data in a circular buffer, trigger on a fault, stop recording, then dump the data to a disk file for analysis. But it would be simpler if you can simply use the Step Response Screen to observe an event.
Correct there is current protection circuitry on the high side supply lines on each of the A side B Side power supply inputs. A side corresponds to Motor Outputs 0-3 and Side B corresponds to Motor Outputs 4-7.
The peak current settings are not precise. They are only intended to protect against shorts that would not be detected and limited by the more precise low side current measurement. See Table here.
Regards
