Does anyone have this issue with their turret? Everything still seems to go okay during part cycles, but I'm rather concerned about this backlash in the turret. Thoughts?
https://youtu.be/twokYUI0tyI
Printable View
In the back of the turret installation manual is instructions on how to correct this. I had to do it to mine.
Direct Document and Software Download | Tormach Inc. providers of personal small CNC machines, CNC tooling, and many more CNC items.
Good luck. I had to work with it a little to get the locking correct.
Mine does the same thing I assume its fine since when cutting the forces will push it one way. I get pretty good tolerances on the x too.
Mine would change based on how much I would take at a pass/cut. Once I adjusted it I have no backlash and the turret stays locked. It was a little time consuming but it is worth the time.
Page 24 has the instructions.
Attachment 310410
Mine locks solid - when correctly adjusted you shouldn't be able to rock the turret even a little, even with a broom handle for added leverage.
Confirmed just totally re aligned and adjusted the turret lock sensor. It is rock solid now.
Jesse
