1 Attachment(s)
Rapid and Block Number Issues in Posts...
1. For some odd reason Edgecam (v. 9.75) converts some of the Z rapids to “maximum high federate” moves. Not all the time, but the majority. I’ve been through the cgd file in Codewizard and checked the appropriate boxes:
NC Style; Rapid Traverse; Convert All Rapids to Feedmoves at Highfeed: Not Selected
Code Constructors; General Motion; Rapid Move, looks like this:
;CODE:%IF #XMOVE=#XHOLD %THEN %GOTO @EXTRAI
;CODE:%IF #YMOVE=#YHOLD %THEN %GOTO @EXTRAI
;CODE:%IF #ZMOVE=#ZHOLD %THEN %GOTO @EXTRAI
[RAPIDGCODE][ZMOVE][FEED][COOLANT ON]
;CODE:%GOTO @FINAL
;CODE:@EXTRAI
[RAPIDGCODE][XMOVE][YMOVE][ZMOVE][FEED][COOLANT ON]
;CODE:@FINAL
(2) Block numbers also do not post despite having checked “Output Block Numbers,” Block Numbers Start: 10, and Block Increment: 10.
Is there something I’m missing or incorrectly set?
Setup is as follows:
-Edgecam v9.75 running solid models
-Cincinnati Sabre 1000 VMC
-Acramatic 850SX Controller w/ Fanuc AC Drives and Servos
Text file of an example post is attached. Highfeedrate is set to 500, so F500 finds the offending code which should be G0. Really annoying not being able to resolve what seems like such a simple issue. Is this a bug or are we missing something?
