Re: Ordered a new 12Z today!
Hello,
The clean and flushing of the gear box and spindle is a necessity before any use or powering up. The chines don't have any viable QC and Too Many have found out cast iron fine was the root cause of bearing failure and many lost hours and dollars. If they do indeed do a power wash, say thank you ! and feel lucky.
Quote:
Originally Posted by
Cruiser
Hello,
Thanks. I talked to Paul and he said I could do it if I wanted but at least in mine they dismantled the head and changed the spindle bearing to a better one so it was cleaned at the time. I got the impression they are doing this to all machines now but anyone should check to make sure. I am supposed to change the gearbox oil after a few hours and I will strain that for sure. So far the is one fine machine! I got my nema 43 1600 oz, driver and 60v supply working good on the arduino so next is to figure out the coupler for the X or which belt setup.
Cruiser
Hello,
I just re read what you wrote. I was thinking spindle and you were writing gearbox. Now I'm a little worried. Maybe I should drain and check the gearbox? It has run several hours so far with no problems but maybe I better drain , check and change. Any idea which oil is best?
I was referi9ng to BOTH !
I speak from my case and that of many others from yrs ago. The cast iron fine if any remains in gear box will not come out with a simple drain or even a flush. It would require the gear shafts and bearings removed and then power wash of all insides as the iron fine was stuck to inside of pockets and under bearings by residue of the paint and coolant residue. My gear box was so bad I was forced to go to belt drive. I posted many pic and particulars along with other people who suffered the same experience. Many very good belt designs came of this in the process.
I would suggest doing this to your machine. Have a clean bucket to save oil, after a time to settle it is good to use. In my gut I knew I should have done this from the get go but didn't listen and paid for it !
I would recommend doing this in order to save the gear box, as the gear change ability is good to have. then if you can over run the motor drive for a bit more top speed, it will come in handy for aluminium. You can't beat the gear change for large cutters in steel.
Any place iron fine can rest it is going to be till it has been removed. Any bearing which takes a taste of this iron fine will suffer. Gears won't mind too much at first but soon begin to belly ache and complain with a persistent complaining !
